Help getting rid of Z-banding / visible horizontal layers
Page 2 / 2
marcin.j
(@marcin-j)
Re: Help getting rid of Z-banding / visible horizontal layers
Hi!
I attach pics of my prints...
I tried:
- extruder temp calibration
- e-steps calibration
- check belts
- check pulleys
- check bearings
- reassembling extruder
- modifying spool holder
What I can do more?
I think that it's mechanical problem, not printer settings,
because z-banding is not the same on entire height of prints.
On different height it looks otherwise.
Posted : 01/08/2017 6:43 pm
Hackinistrator
(@hackinistrator)
did you try different filament ?
this is what you'll have if the filament thickness (or mix) is inconsistent .
i would also try new nozzle and check the rigidity of the printer frame .
imho the main frame part connection to the y axis is not solid enough anyways .
Posted : 01/08/2017 8:29 pm
JeffJordan
(@jeffjordan)
Member Moderator
further question: did you get the same results in [silent] mode as well as in [high power] mode ?
and another idea: is your hotend severely fixed inside the extruder body, without any clearance ?
Posted : 01/08/2017 11:27 pm
marcin.j
(@marcin-j)
I tried filament from 3 supliers, PLA and ABS, result the same...
I'll try your suggestions, thank you!
I worked only in high power mode.
I checked hotend, I replaced PTFE tube to be convinced that everything is OK.
Everything is firmly fixed...
I tried to pull filament inside manually, and I didn't notice any clearence.
Posted : 02/08/2017 9:56 am
Skiid
(@skiid)
How was this resolved? Lots of info here with no solution.
Posted : 05/04/2018 10:11 pm
christherock23
(@christherock23)
Did anybody find a solution to this? I too am being haunted by this Z banding and i am running out of parts to replace :/
Posted : 03/05/2018 10:30 am
Page 2 / 2
