XYZ calibration problem after changing to Titan aero exstruder
Hi i changed to a Titan aero and had to change homing and xy coordination.
The problem is the z axis is to high when it tries to do xyz calibration, it lands the sensor perfectly in the right location and the first point works fine but on the second point the sensor is high over (1 cm) the bed and the sesor fails to trigger.
-cant find calibration point. is the error message but its obvious its not going to find it at that hight on the z axis.
How do i get the caligration to lower itself to the same hight as the first point? i can t figure it out.
Re: XYZ calibration problem after changing to Titan aero exstruder
Did you change anythig in firmware?
Where is PINDA in relation to the Aero nozzle?
Bill
Tagaytay City, Philippines
