Selftest Left Fan Wiring Error
ianstock
(@ianstock)
After months of normal operation, I am getting a Selftest error regarding the left fan wiring.
The fan works.  I put 5VDC to it and it spins.
Without the fan plugged in there is 5 VDC across the pins on the board, but as soon as I plug in the fan this drops to less than 1 VDC, and I again get the error message.
Any idea why the power would drop on load but not on open circuit?  What's going on?
Ian
Toronto, Canada
Posted : 25/10/2019 1:00 pm
alexander.s27
(@alexander-s27)
RE: Selftest Left Fan Wiring Error
I guess a broken cable with a Short.
Posted : 26/10/2019 4:59 am
wyldeturkey
(@wyldeturkey)
Did you ever figure out a fix for this? This started happening to me so i started the test after i pre-heated it and it would get past that part of the test. Then it'd fail on testing the Bed/Heater Wiring error. Not sure where to go from here, the wiring is fine, i can actually still print with the thing i believe it just really bugs me that it doesn't pass this test.
Posted : 15/07/2020 8:43 pm
