					                		MK52 12V Bed - Hardware, firmware and software help                                    </title>
                <link>https://forum.prusa3d.com/forum/original-prusa-i3-mk2-s-hardware-firmware-and-software-help/mk52-12v-bed/</link>
                <lastBuildDate>Mon, 15 Jun 2026 01:55:31 +0000</lastBuildDate>
                        <title>RE: MK52 12V Bed</title>
                        <link>https://forum.prusa3d.com/forum/original-prusa-i3-mk2-s-hardware-firmware-and-software-help/mk52-12v-bed/#post-620812</link>
                        <pubDate>Tue, 20 Sep 2022 12:27:29 +0000</pubDate>
                        <description><![CDATA[If I could learn how to do firmware then I would just add a sticker to my frame to update firmware code before flashing new firmware.  I use to do some of that with my first 3D printer but t...]]></description>
                        <content:encoded><![CDATA[<p>If I could learn how to do firmware then I would just add a sticker to my frame to update firmware code before flashing new firmware.  I use to do some of that with my first 3D printer but that was almost a decade ago...before I got the MK2 and didn't need to do that stuff anymore.</p>]]></content:encoded>
                        <category domain="https://forum.prusa3d.com/forum/original-prusa-i3-mk2-s-hardware-firmware-and-software-help/">Hardware, firmware and software help</category>                        <dc:creator>jella_joe</dc:creator>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/original-prusa-i3-mk2-s-hardware-firmware-and-software-help/mk52-12v-bed/#post-620812</guid>
                        <link>https://forum.prusa3d.com/forum/original-prusa-i3-mk2-s-hardware-firmware-and-software-help/mk52-12v-bed/#post-620810</link>
                        <pubDate>Tue, 20 Sep 2022 12:24:51 +0000</pubDate>
                        <description><![CDATA[I have installed the bed and it is working.  I was thinking about trying to update the firmware but now I am hesitant.  I went back to find the other posts where this topic was discussed and...]]></description>
                        <content:encoded><![CDATA[<p>I have installed the bed and it is working.  I was thinking about trying to update the firmware but now I am hesitant.  I went back to find the other posts where this topic was discussed and ended up frustrated.  The guy asking the questions has a system that seems to be a mishmash of MK2.5, MK3 and MK2.  I have a simple MK2 with a magnetic bed.  lol.</p>]]></content:encoded>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/original-prusa-i3-mk2-s-hardware-firmware-and-software-help/mk52-12v-bed/#post-620810</guid>
                        <link>https://forum.prusa3d.com/forum/original-prusa-i3-mk2-s-hardware-firmware-and-software-help/mk52-12v-bed/#post-609763</link>
                        <pubDate>Mon, 13 Jun 2022 20:34:32 +0000</pubDate>
                        <description><![CDATA[Hi Jella Joe, If you are comfortable, modifying firmware, you could &#039;re map&#039; the XYZ calibration sense points to match the sense points on the Mk52 12 volt heatbed, and then swap to the new ...]]></description>
                        <content:encoded><![CDATA[<p>Hi Jella Joe, <br />If you are comfortable, modifying firmware, you could 're map' the XYZ calibration sense points to match the sense points on the Mk52 12 volt heatbed, and then swap to the new heatbed. <br />BUT. if ever there is an updated firmware, you would have to re edit it again to restore servicability with the Mk52 heatbed. <br /><br />As I have just mentioned in another post. <br />I swapped to the new heat bed, knowing and accepting that XYZ Configuration will no longer work, and I simply print straight on the removable build plate. <br />I need to do the initial Live Z calibration, after changing to the new setup. and I need to repeat the live Z calibration if I change the heatbed. <br />the PEI Heatbed is thicker than both the silk and textured heatbeds, so the smooth PEI needs a different live Z value, to achieve good prints!<br /><br />I use the same filament profiles as the original Mk2 before the change of heatbed. <br /><br /><br />Regards Joan</p>]]></content:encoded>
                        <category domain="https://forum.prusa3d.com/forum/original-prusa-i3-mk2-s-hardware-firmware-and-software-help/">Hardware, firmware and software help</category>                        <dc:creator>JoanTabb</dc:creator>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/original-prusa-i3-mk2-s-hardware-firmware-and-software-help/mk52-12v-bed/#post-609763</guid>
                        <title>MK52 12V Bed</title>
                        <link>https://forum.prusa3d.com/forum/original-prusa-i3-mk2-s-hardware-firmware-and-software-help/mk52-12v-bed/#post-609748</link>
                        <pubDate>Mon, 13 Jun 2022 17:40:32 +0000</pubDate>
                        <description><![CDATA[Hey everyone,Can you just jump to the new bed?  Is there something I can simply change in the code to make it work?]]></description>
                        <content:encoded><![CDATA[<p>Hey everyone,</p><p>Can you just jump to the new bed?  Is there something I can simply change in the code to make it work?</p><p> </p>]]></content:encoded>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/original-prusa-i3-mk2-s-hardware-firmware-and-software-help/mk52-12v-bed/#post-609748</guid>
