Heat bed suddenly stopped working
kristian.r2
(@kristian-r2)
In the middle of a print, the heat bed suddenly stopped working. Everything works fine with the exception of the heat bed
Troubleshooting:
  • LED on heat bed connector - No
  • LED6 on mini-Rambo - No
  • Power input (X10 AB, and X10 CD) – 12V, Molex connectors ok
  • F3 Fuse (15A) – Ok
  • Terminals on heat bed - Ok
  • Heat bed cable – Ok
  • Heat bed resistance – 0.9 Ohm
  • Heat bed connector (X3 AB) – OK
  • 12V3 – 10.55V when idle, 11.85V when heat bed and hot end is set active
I have gone through the wire diagram and verified all component, where everything seems to be ok. The mostfet is difficult to test without de-soldering it, but there are no short circuits which would be natural of a mosfet failure.
What I did found was that the PWM output (port 1) on the Atmel I only gave 0,85V when heat bed was supposed to be on. When the target setting is set well above the thermistor readback, I would expect something in the range of 4.5-5V?! The PWM output (port 2) for the hot end shows 4.99V when activated.
I have done a factory reset and upgraded to the latest firmware – heat bed still not working
This is actually the second time this happens – last time I replaced the mini-rambo with a second hand piece I got my hands on.
Any thought? Please help.
Posted : 04/06/2022 9:11 am
RE: Heat bed suddenly stopped working
Any success?  Have you contacted support via chat?
Posted : 13/06/2022 9:38 am
jella_joe
(@jella_joe)
That was what happened to me a few times before my PSU capacitor died.  I had to get a new PSU.  I inserted the one that I purchased because Prusa does not carry the PSU for the MK2 anymore.  Good luck!
https://smile.amazon.com/dp/B00D7CWSCG?psc=1&ref=ppx_yo2ov_dt_b_product_details
Posted : 20/09/2022 9:57 am
