Front fan not working
Updated to latest firmware and went to print something and noticed the fan didn't kick on. So went into settings and tried turning the fan speed all the way up and nothing. ordered a new prusa fan replacement hooked it up and still nothing. Any ideas?
RE: Front fan not working
I now have this same issue, did you ever figure out what it was?
@nathan-m2
It was the mini-rambo, not sure if the update messed it up or if it was just coincidence, but the fan plugin was dead. I ordered one from newegg for cheaper and it works perfect now.
Just noticed the same thing. Updated to 3.2.3 and now front fan does not run. nathan-m2 What fan plugin was dead? Do you have a part number or link for newegg? Are you sure its just not the firmware update causing the issue?
Thanks for your input!
John
