Fine tuning filament settings
Tom
 Tom
(@tom)
Hello,
Got a few MK2's running at home but I always print on the default settings Prusa provides.
I'm pretty sure I could dial in my filament settings much better, since every spool, brand, color will be a little different.
I guess it's probably also best to dial in my printer settings, since every build is different?
Does anyone here has a good procedure on how to really fine tune your print settings well for each filament brand,... ?
Cheers,
Tom
Posted : 19/12/2017 10:19 am
Tom
 Tom
(@tom)
Re: Fine tuning filament settings
Nobody? 😮
Posted : 23/12/2017 2:50 pm
We are scared to answer lol in case others laugh...
My mk 3 is staoled at the build x axis point because christmas got in the way...
Regards Joan
Posted : 23/12/2017 8:39 pm
Luckily we are eating out tomorrow and christmas day... the living room table is full of printer...
Joan
Posted : 23/12/2017 8:40 pm
Sebastianmaklary
(@sebastianmaklary)
I've only printed almost 1 kg of the filament that was shipped with the printer and almost 1 kg of some that I got as a christmas present 2 years ago when I thought i would recieve a printer using kickstarter.
Anyway, my experience with those 2 is that one of them is a tiny bit more runny than the other, producing more stringy stuff when the print head moves through air. experience:
Temp settings 200 or 210 degrees: little change.
Retraction length raised from 0,8mm to 1mm: little change.
K-factor raised from 30 to 35 or 40: gives underextrusion with direction changes so requires more overlap between perimeters and infill but that might give other issues.
Posted : 23/12/2017 9:38 pm
Tom
 Tom
(@tom)
Nobody will laugh!
Not really the answer I was looking for Sebastian, but thanks!
I'm just curious if you guy use a temperature tower, to check which temperature provides best bonding, less stringing, overall quality, ... Or just something totally different.
Posted : 28/12/2017 6:15 pm
