Filament needs unloaded and reloaded after all prints
yuggniiks
(@yuggniiks)
After a print is complete my filament needs to be unloaded and reloaded. The filament will actually be loose, and you can pull it out from the tension idler. Could this be the entire hotend assembly, or should I start with replacing the thermister?
Thoughts?
Thanks!
Posted : 28/03/2019 5:16 pm
BillC
(@billc)
Re: Filament needs unloaded and reloaded after all prints
post your printer settings custom gcode end code. Sounds as though you have an unload instruction in the code.
Bill
Tagaytay City, Philippines
Posted : 29/03/2019 1:01 pm
yuggniiks
(@yuggniiks)
G1 E-4 F2100.00000
G91
G1 Z1 F7200.000
G90
G1 X245 Y1
G1 X240 E4
G1 F4000
G1 X190 E2.7
G1 F4600
G1 X110 E2.8
G1 F5200
G1 X40 E3
G1 E-15.0000 F5000
G1 E-50.0000 F5400
G1 E-15.0000 F3000
G1 E-12.0000 F2000
G1 F1600
G1 X0 Y1 E3.0000
G1 X50 Y1 E-5.0000
G1 F2000
G1 X0 Y1 E5.0000
G1 X50 Y1 E-5.0000
G1 F2400
G1 X0 Y1 E5.0000
G1 X50 Y1 E-5.0000
G1 F2400
G1 X0 Y1 E5.0000
G1 X50 Y1 E-3.0000
G4 S0
M107 ; turn off fan
{if layer_z < max_print_height}G1 Z{z_offset+min(layer_z+30, max_print_height)}{endif} ; Move print head up
M104 S0 ; turn off temperature
M140 S0 ; turn off heatbed
G28 X0 ; home X axis
M84 ; disable motors
Posted : 29/03/2019 3:16 pm
BillC
(@billc)
G1 E-15.0000 F5000
G1 E-50.0000 F5400
G1 E-15.0000 F3000
G1 E-12.0000 F2000
That's the end of your file, not the end gcode from slic3r but the lines I have quoted cause an awful lot of extruder movement. Those instructions tell the extruder to back out a total of 92mm of filament. It will back out until the drive gear loses grip and then sit loose. Any further extruder move requests will have nothing to work with.
If you investigate where the quoted commands are generated from and eliminate that, your problem should be solved.
Happy printing.
Bill
Posted : 01/04/2019 2:10 am
yuggniiks
(@yuggniiks)
Thanks for looking through my gcode.
I ended up reinstalling slic3r and that seems to have solved my problems!
Thanks for your time! 😀
Posted : 01/04/2019 4:07 pm
