extr. fan error after new card and firmware update
I just put a new rambo card in a mk2 i3 printer and it asks for a firmware update.
after doing so I get a extr. fan error, I tried a different fan and it did the same, 9 side hot end fan)
I used the mk2.5s firmware the first time and checked that i had the right one, i found one for the mk2 i3 and used it and the error went away but now it asks for the 3.9.3 firmware.
https://shop.prusa3d.com/en/mk2mk2s/49-rambo-mini.html&source=gmail&ust=1616024743740000&usg=AFQjCNHHVW_aWaGTV7mxx_kNbYcMohNre Q"> https://shop.prusa3d.com/en/mk2mk2s/49-rambo-mini.html
this is the card i put into a mk2 i3 (no removable bed sheet)
Do I have the wrong card or something?
The fan wire only has two wires, do the newer printers have an extra wire for speed sensing?
Bill
Publié : 17/03/2021 12:51 am
RE: extr. fan error after new card and firmware update
Hi Bill,
the card identified is the Original RAMBO Card as used for Mk1, Mk2, Mk2S, Mk2.5 printers
the Mk2 printer has a small (30mm?) two wire fan on the left of the extruder, and a two wire turbofan on the front of the extruder
it also has an original 3 wire Pinda (Not SupaPinda, and not 4 Wire Pinda2)
the heater is 12 volts and it uses a Mk42 Heatbed.
and the Prusa Slicer needs to have the Mk2S printer profile chosen.
Publié : 17/03/2021 1:04 am
