					                		Disable firmware update message? - Hardware, firmware and software help                                    </title>
                <link>https://forum.prusa3d.com/forum/original-prusa-i3-mk2-s-hardware-firmware-and-software-help/disable-firmware-update-message/</link>
                <lastBuildDate>Sun, 17 May 2026 09:34:24 +0000</lastBuildDate>
                        <title>RE: Disable firmware update message?</title>
                        <link>https://forum.prusa3d.com/forum/original-prusa-i3-mk2-s-hardware-firmware-and-software-help/disable-firmware-update-message/#post-702100</link>
                        <pubDate>Sat, 02 Mar 2024 10:10:48 +0000</pubDate>
                        <description><![CDATA[Thanks]]></description>
                        <content:encoded><![CDATA[<p>Thanks </p>]]></content:encoded>
                        <category domain="https://forum.prusa3d.com/forum/original-prusa-i3-mk2-s-hardware-firmware-and-software-help/">Hardware, firmware and software help</category>                        <dc:creator>Neuraldeepnet</dc:creator>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/original-prusa-i3-mk2-s-hardware-firmware-and-software-help/disable-firmware-update-message/#post-702100</guid>
                        <link>https://forum.prusa3d.com/forum/original-prusa-i3-mk2-s-hardware-firmware-and-software-help/disable-firmware-update-message/#post-679377</link>
                        <pubDate>Tue, 17 Oct 2023 09:27:20 +0000</pubDate>
                        <description><![CDATA[Posted by: @borisuk Excellent, thanks. I removed the M115 line from the &quot;Start G-code&quot; sectionAll good happy to help]]></description>
                        <content:encoded><![CDATA[<p> </p><blockquote data-userid="500346" data-postid="679363" data-mention="borisuk"><div class="wpforo-post-quote-author"><strong> Posted by: @borisuk </strong></div><p>Excellent, thanks. I removed the M115 line from the "Start G-code" section</p></blockquote><p>All good happy to help</p>]]></content:encoded>
                        <category domain="https://forum.prusa3d.com/forum/original-prusa-i3-mk2-s-hardware-firmware-and-software-help/">Hardware, firmware and software help</category>                        <dc:creator>Hello</dc:creator>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/original-prusa-i3-mk2-s-hardware-firmware-and-software-help/disable-firmware-update-message/#post-679377</guid>
                        <link>https://forum.prusa3d.com/forum/original-prusa-i3-mk2-s-hardware-firmware-and-software-help/disable-firmware-update-message/#post-679363</link>
                        <pubDate>Tue, 17 Oct 2023 07:00:19 +0000</pubDate>
                        <description><![CDATA[Excellent, thanks. I removed the M115 line from the &quot;Start G-code&quot; section]]></description>
                        <content:encoded><![CDATA[<p>Excellent, thanks. I removed the M115 line from the "Start G-code" section</p>]]></content:encoded>
                        <category domain="https://forum.prusa3d.com/forum/original-prusa-i3-mk2-s-hardware-firmware-and-software-help/">Hardware, firmware and software help</category>                        <dc:creator>BorisUK</dc:creator>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/original-prusa-i3-mk2-s-hardware-firmware-and-software-help/disable-firmware-update-message/#post-679363</guid>
                        <link>https://forum.prusa3d.com/forum/original-prusa-i3-mk2-s-hardware-firmware-and-software-help/disable-firmware-update-message/#post-679343</link>
                        <pubDate>Mon, 16 Oct 2023 23:09:39 +0000</pubDate>
                        <description><![CDATA[Posted by: @borisuk I know that I can remove M115 line from the gcode, but I do not want to do that every time I slice a model and export the gcode. Is there a way to stop PrusaSlicer from e...]]></description>
                        <content:encoded><![CDATA[<p> </p><blockquote data-userid="500346" data-postid="679333" data-mention="borisuk"><div class="wpforo-post-quote-author"><strong> Posted by: @borisuk </strong></div><p>I know that I can remove <strong>M115</strong> line from the gcode, but I do not want to do that every time I slice a model and export the gcode. Is there a way to stop PrusaSlicer from exporting the firmware check instructions? I can't upgrade my printers to 3.12+ because of the thermal anomaly check Prusa introduced in this version. Disabling the check in <strong>Settings -&gt; HW setup -&gt; Checks -&gt; Firmware</strong> does not work</p></blockquote><p>In prusa slicer at the top of thenplatter there will be some tabs click print settings then I think it's custom gcode then delete the command then close prusaslicer and click save it will then stop outputting it every slice</p>]]></content:encoded>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/original-prusa-i3-mk2-s-hardware-firmware-and-software-help/disable-firmware-update-message/#post-679343</guid>
                        <link>https://forum.prusa3d.com/forum/original-prusa-i3-mk2-s-hardware-firmware-and-software-help/disable-firmware-update-message/#post-679333</link>
                        <pubDate>Mon, 16 Oct 2023 20:57:01 +0000</pubDate>
                        <description><![CDATA[I know that I can remove M115 line from the gcode, but I do not want to do that every time I slice a model and export the gcode. Is there a way to stop PrusaSlicer from exporting the firmwar...]]></description>
                        <content:encoded><![CDATA[<p>I know that I can remove <strong>M115</strong> line from the gcode, but I do not want to do that every time I slice a model and export the gcode. Is there a way to stop PrusaSlicer from exporting the firmware check instructions? I can't upgrade my printers to 3.12+ because of the thermal anomaly check Prusa introduced in this version. Disabling the check in <strong>Settings -&gt; HW setup -&gt; Checks -&gt; Firmware</strong> does not work</p>]]></content:encoded>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/original-prusa-i3-mk2-s-hardware-firmware-and-software-help/disable-firmware-update-message/#post-679333</guid>
                        <link>https://forum.prusa3d.com/forum/original-prusa-i3-mk2-s-hardware-firmware-and-software-help/disable-firmware-update-message/#post-679316</link>
                        <pubDate>Mon, 16 Oct 2023 19:30:09 +0000</pubDate>
                        <description><![CDATA[Posted by: @orbital this didn&#039;t work for me, the messages are still showing. on 3.11 (anything higher and i get whack thermal anomolies because of my sock + lots of phantom crashes + z calib...]]></description>
                        <content:encoded><![CDATA[<p> </p><blockquote data-userid="538929" data-postid="679263" data-mention="orbital"><div class="wpforo-post-quote-author"><strong> Posted by: @orbital </strong></div><p>this didn't work for me, the messages are still showing. on 3.11 (anything higher and i get whack thermal anomolies because of my sock + lots of phantom crashes + z calibration issues).</p></blockquote><p>In prusa slicer go to start gcode and delete where it says check latest firmware delete that row</p>]]></content:encoded>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/original-prusa-i3-mk2-s-hardware-firmware-and-software-help/disable-firmware-update-message/#post-679316</guid>
                        <link>https://forum.prusa3d.com/forum/original-prusa-i3-mk2-s-hardware-firmware-and-software-help/disable-firmware-update-message/#post-679263</link>
                        <pubDate>Mon, 16 Oct 2023 15:40:03 +0000</pubDate>
                        <description><![CDATA[this didn&#039;t work for me, the messages are still showing. on 3.11 (anything higher and i get whack thermal anomolies because of my sock + lots of phantom crashes + z calibration issues).]]></description>
                        <content:encoded><![CDATA[<p>this didn't work for me, the messages are still showing. on 3.11 (anything higher and i get whack thermal anomolies because of my sock + lots of phantom crashes + z calibration issues).</p>]]></content:encoded>
                        <category domain="https://forum.prusa3d.com/forum/original-prusa-i3-mk2-s-hardware-firmware-and-software-help/">Hardware, firmware and software help</category>                        <dc:creator>Orbital</dc:creator>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/original-prusa-i3-mk2-s-hardware-firmware-and-software-help/disable-firmware-update-message/#post-679263</guid>
                        <link>https://forum.prusa3d.com/forum/original-prusa-i3-mk2-s-hardware-firmware-and-software-help/disable-firmware-update-message/#post-206247</link>
                        <pubDate>Wed, 08 Apr 2020 19:43:26 +0000</pubDate>
                        <description><![CDATA[Thank you!]]></description>
                        <content:encoded><![CDATA[<p>Thank you!</p>]]></content:encoded>
                        <category domain="https://forum.prusa3d.com/forum/original-prusa-i3-mk2-s-hardware-firmware-and-software-help/">Hardware, firmware and software help</category>                        <dc:creator>dejan.k</dc:creator>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/original-prusa-i3-mk2-s-hardware-firmware-and-software-help/disable-firmware-update-message/#post-206247</guid>
                        <link>https://forum.prusa3d.com/forum/original-prusa-i3-mk2-s-hardware-firmware-and-software-help/disable-firmware-update-message/#post-206197</link>
                        <pubDate>Wed, 08 Apr 2020 18:21:12 +0000</pubDate>
                        <description><![CDATA[Printer menu -&gt; Settings -&gt; HW setup -&gt; Checks -&gt; Firmware]]></description>
                        <content:encoded><![CDATA[<p>Printer menu -&gt; Settings -&gt; HW setup -&gt; Checks -&gt; Firmware</p>]]></content:encoded>
                        <category domain="https://forum.prusa3d.com/forum/original-prusa-i3-mk2-s-hardware-firmware-and-software-help/">Hardware, firmware and software help</category>                        <dc:creator>Lichtjaeger</dc:creator>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/original-prusa-i3-mk2-s-hardware-firmware-and-software-help/disable-firmware-update-message/#post-206197</guid>
                        <title>Disable firmware update message?</title>
                        <link>https://forum.prusa3d.com/forum/original-prusa-i3-mk2-s-hardware-firmware-and-software-help/disable-firmware-update-message/#post-206184</link>
                        <pubDate>Wed, 08 Apr 2020 17:56:38 +0000</pubDate>
                        <description><![CDATA[Is there any way to disable the new firmware upgrade message I get on my mk2 when starting print?]]></description>
                        <content:encoded><![CDATA[<p>Is there any way to disable the new firmware upgrade message I get on my mk2 when starting print?</p>]]></content:encoded>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/original-prusa-i3-mk2-s-hardware-firmware-and-software-help/disable-firmware-update-message/#post-206184</guid>
