Disable firmware update message?
dejan.k
(@dejan-k)
Is there any way to disable the new firmware upgrade message I get on my mk2 when starting print?
Publié : 08/04/2020 5:56 pm
1 personnes ont aimé
Lichtjaeger
(@lichtjaeger)
RE: Disable firmware update message?
Printer menu -> Settings -> HW setup -> Checks -> Firmware
Publié : 08/04/2020 6:21 pm
2 personnes ont aimé
dejan.k
(@dejan-k)
Thank you!
Publié : 08/04/2020 7:43 pm
Orbital
(@orbital)
Membre
this didn't work for me, the messages are still showing. on 3.11 (anything higher and i get whack thermal anomolies because of my sock + lots of phantom crashes + z calibration issues).
Publié : 16/10/2023 3:40 pm
Hello
(@hello)
Posted by: @orbital
In prusa slicer go to start gcode and delete where it says check latest firmware delete that row
Publié : 16/10/2023 7:30 pm
BorisUK
(@borisuk)
I know that I can remove M115 line from the gcode, but I do not want to do that every time I slice a model and export the gcode. Is there a way to stop PrusaSlicer from exporting the firmware check instructions? I can't upgrade my printers to 3.12+ because of the thermal anomaly check Prusa introduced in this version. Disabling the check in Settings -> HW setup -> Checks -> Firmware does not work
Publié : 16/10/2023 8:57 pm
Hello
(@hello)
Posted by: @borisuk
In prusa slicer at the top of thenplatter there will be some tabs click print settings then I think it's custom gcode then delete the command then close prusaslicer and click save it will then stop outputting it every slice
Publié : 16/10/2023 11:09 pm
BorisUK
(@borisuk)
Excellent, thanks. I removed the M115 line from the "Start G-code" section
Publié : 17/10/2023 7:00 am
Hello
(@hello)
Posted by: @borisuk
All good happy to help
Publié : 17/10/2023 9:27 am
Neuraldeepnet
(@neuraldeepnet)
Thanks
Publié : 02/03/2024 10:10 am
