Broken or glitched LCD panel?
Tim N
(@tim-n-2)
I'm not sure if my LCD panel on my Prusa printer is broken or glitched. At first there was a line of dead pixels. This can still be seen on the top row the 7th square from the left. Then the LCD pannel started showing only white squares. I tried the fix of updating the firm ware but that did not work. Next I tried to reset the printer which also does not work. Along with checking all the connections to make sure they are secure.
The printer works fine and still prints from Pronterface. However I cannot calibrate it. Do I need to buy a new panel and install it or is there a way to fix it?
Posted : 11/06/2018 7:47 pm
