ORIGINAL PRUSA I3 MK2S RELEASE (UPDATED)
Page 8 / 8
Danlad1631
(@danlad1631)
Re: ORIGINAL PRUSA I3 MK2S RELEASE (UPDATED)
Lol
Posted : 17/05/2017 5:13 pm
JJ3DPrinter
(@jj3dprinter)
I'm printing my parts in PETG and need to know what parts have changed from the stock MK2. From what I've read it seem they changed: extruder body, x-carriage, and the Y-distance.
What about the Rambo changed (Door and Base) as I'm not sure what to print on this one
Are there any other parts I'm missing?
Posted : 19/05/2017 6:25 am
Alomamabobo
(@alomamabobo)
@jeff.j2: Rambo door didn't change 🙂
Good day.
Prusa i3 MK2S firmware 3.1.0.
FlashAir card.
Posted : 21/05/2017 3:11 pm
Asraff Amzani
(@asraff-amzani)
the upgrade kit just came today, was thinking that I should print all of the mk2s parts and convert fully to mk2s instead of partial. I know this has been questioned before, any recommended print parameters?
mine currently is:
- perimeters 3
- top/bottom 3
- infill type cubic
- infill 20%
Was thinking of turning on brim to improve adhesion so the parts come out perfect
The supplied filament is 100g of ABS-T. I never handled such thing
Posted : 03/06/2017 8:44 am
christopher.d3
(@christopher-d3)
Ok, I'm incompetant - I ruined four of the linear bearings. Where can I get some high quality replacements? I'm not sure how to evaluate available units.
Posted : 05/06/2017 3:27 pm
PJR
 PJR
(@pjr)
Antient Member Moderator
For the most part, I think it's just pot luck. Yes, you can pay a lot of money and get them from a known manufacturer (eg Misumi), but I am not convinced that is good value for money.
Peter
Posted : 05/06/2017 3:37 pm
Asraff Amzani
(@asraff-amzani)
Just upgraded mine to mk2s, gotta say that the upgrade made an impact to the resonance of the frames
Posted : 09/06/2017 11:22 am
carl.b2
(@carl-b2)
I am in the process of installing the MK2S upgrade. As instructed, I printed the gcode parts. I could not get the ABS that Prusa shipped with the kit to stick to the bed. I had a spool of ABS (Manufacturer Unknown) and use it to print the parts. During assembly I had real problems with the Extruder part I printed. All of the holes were too small. I had to really work to get the square nuts into the hole slots. The PINDA would not fit in the hole. With reluctance, I drilled out the mounting hole so I could get it in. I could not tell but I hope I did not drill it so much that it was past the wall thickness of the hole. Apparently the ABS I have has greater shrinkage than the Prusa ABS. ❓
I did not have any PET Filament to print the PET gcode files and had no way of knowing what they were. While routing the cable I discovered it was asking for the cable holders. I was able to go the the MK2S parts list and figure out what they were. I have another printer ( a CR-10) and printed the cable holders using PLA. I am now ready to finish the assembly.
I wish Prusa would have included the ABS parts in the kit.
Posted : 17/06/2017 4:48 pm
michael.e3
(@michael-e3)
So this mentions upgrading your smooth rods, but after searching the forums I can't find a recommendation for them, I already bought the U-Bolts separate since I already printed the printable parts, and I was buying a new bed anyways, but they don't have them on their store and I can't find a specific spec for them or a part #.
Does anyone have a link for what they got, and how are they working?
Much appreciated 😀
Posted : 06/07/2017 12:26 am
richard.s11
(@richard-s11)
Gcode for upgrade parts - which nozzle diameter?
Hello!
Just got the upgrade kit. Some questions about printing parts:
1: If I use the gcode, which nozzle diameter is presumed?
2: If I choose the STL-files instead, which nozzle diameter, layer height, wall/bottom/top thickness, fill% etc. is recommended?
Thx in advance,
/RS
Posted : 29/10/2017 9:15 pm
DevDoc
(@devdoc)
1. The gcode is for .4mm nozzle
2. .4mm Nozzle. The normal or fast preset using ABS material in Slic3r PE works fine or in the alternative: .2-.3 layer height, 2 perimeters, 3-4 top and bottom layers,30% cubic infill
These certainly are not the only answers possible, but they work perfectly on my units. You can certainly go more on anything, but I think you are simply adding weight at that point. PLA\PET\PETG is also known to work if ABS is impractical or not on hand.
Posted : 02/11/2017 4:56 pm
malcolm.r
(@malcolm-r)
Hello All 😉
Clarification question please on the material, filament, for printing the MK2 to MK2s upgrade.
I would like to use PETG for all the parts not just the RAMBO cover.
Has anyone already done this? How are the results? Any heat deformation after printing for a while?
Any and all input appreciated! 💡
cheers
mr
If you want something different for tomorrow you have to DO something different today. 💡
Posted : 19/11/2017 12:42 am
ron-f
(@ron-f)
You should absolutly avoid using PETG for parts around the hotend and noozle. That concern 3 parts I think. 2 around the extruder + the fan duct.
Posted : 19/11/2017 4:13 pm
jose.f5
(@jose-f5)
Hello All 😉
cheers
mr
I tried it and the part that warped was the estruder cover. the body seemed to take the heat fine, but the extruder cover did not, I believe its because it is so close to the actual block.
JEF SSgt/USMC Ret.
Posted : 23/11/2017 5:53 am
Page 8 / 8
