Nozzle stops?
Hi
I have a Prusa i3 MK2s from 2017 which have running perfect until now 🙁
It seams the nuzzle stops. Therefore I have change nozzle and the ptfe tube for the filament, but i does still stops.
Here are a sample of a print where the nozzle stops and the printer have continued with out filament:
After a print I heat up the hot-end and then remove the filament. I can see the feeder have tried to run filament to the nuzzle and have "eaten" the filament.
When I look at the hot-end it seams to be "normal":
I have tried to reset the Prusa slicer to default, to ensure it not some settings I have made wronge.
Any suggestion how I get my Prusa running agian?
RE: Nozzle stops?
First i would remove the nozzle and try another one. If this does not work, remove the hotend/heatbreak and try to clean them and/or change the PTFE tube.
