					                		Live Adjust Z: Every print seems to need progressively more offset - General discussion, announcements and releases                                    </title>
                <link>https://forum.prusa3d.com/forum/original-prusa-i3-mk2-s-general-discussion-announcements-and-releases/live-adjust-z-every-print-seems-to-need-progressively-more-offset/</link>
                <lastBuildDate>Mon, 18 May 2026 06:17:38 +0000</lastBuildDate>
                        <title>RE: Live Adjust Z: Every print seems to need progressively more offset</title>
                        <link>https://forum.prusa3d.com/forum/original-prusa-i3-mk2-s-general-discussion-announcements-and-releases/live-adjust-z-every-print-seems-to-need-progressively-more-offset/#post-608469</link>
                        <pubDate>Tue, 31 May 2022 09:12:40 +0000</pubDate>
                        <description><![CDATA[I had exactly the same problem. Only after &quot;Calibration -&gt; First layer cal.&quot; was executed, the setting remained permanently saved. Before that, live Z had to be adjusted for each print.]]></description>
                        <content:encoded><![CDATA[<p>I had exactly the same problem. Only after "Calibration -&gt; First layer cal." was executed, the setting remained permanently saved. Before that, live Z had to be adjusted for each print.</p>]]></content:encoded>
                        <category domain="https://forum.prusa3d.com/forum/original-prusa-i3-mk2-s-general-discussion-announcements-and-releases/">General discussion, announcements and releases</category>                        <dc:creator>PhosphOr</dc:creator>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/original-prusa-i3-mk2-s-general-discussion-announcements-and-releases/live-adjust-z-every-print-seems-to-need-progressively-more-offset/#post-608469</guid>
                        <title>Live Adjust Z: Every print seems to need progressively more offset</title>
                        <link>https://forum.prusa3d.com/forum/original-prusa-i3-mk2-s-general-discussion-announcements-and-releases/live-adjust-z-every-print-seems-to-need-progressively-more-offset/#post-606227</link>
                        <pubDate>Sun, 08 May 2022 03:59:12 +0000</pubDate>
                        <description><![CDATA[I&#039;ve been printing successfully for a long time but something funny just started happening. I recently did a Z cal after needing to disassemble some things to pull out a jammed filament. Aft...]]></description>
                        <content:encoded><![CDATA[<p>I've been printing successfully for a long time but something funny just started happening. I recently did a Z cal after needing to disassemble some things to pull out a jammed filament. After I calibrated I printed a simple test to live adjust Z .. I found that a setting of about -1.0 mm worked well. On my next print though I could see really poor adhesion so I had to again go to live adjust Z and set it to -2.0 mm to get it to work ... now on my 3rd print .. you guessed it .. I had to go to -3mm. It's as if it keeps forgetting my live adjust value and going to the original Z setting .. and I have to increment live adjust Z by 1.0 mm every time. Any ideas on what may be happening? Thanks!!</p>]]></content:encoded>
                        <category domain="https://forum.prusa3d.com/forum/original-prusa-i3-mk2-s-general-discussion-announcements-and-releases/">General discussion, announcements and releases</category>                        <dc:creator>amess</dc:creator>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/original-prusa-i3-mk2-s-general-discussion-announcements-and-releases/live-adjust-z-every-print-seems-to-need-progressively-more-offset/#post-606227</guid>
