HELP! extruder problem
HELP! i have finally gotten my hands on a prusa i3 mk2 upgraded to S. Got it second hand. Everything seems nice, but when i press load filament, the extruder motor turns counter clockwise!?! when i press unload it turns clockwise. Isn`t it supose to be the other way around? i am heartbroken as i was really looking forward to do my first print:😭😭
Re: HELP! extruder problem
Hi Borge,
Make sure it has the correct firmware loaded
https://www.prusa3d.com/drivers/
i have checked. And it says 3.1.0. When i try to re flash the firmware it gets an timeout error :/ when i try to load filament it gives me option to load filament 1-4. Is this an indication that it has wrong firmware? i do not have multimaterial
Both MK2S and MK2S Multimaterial are on ver 3.1.0 firmware, but they are different files. Get the correct one from here, you probably want the 664kb file UNLESS you DON'T have the 13a Rambo https://github.com/prusa3d/Prusa-Firmware/releases/tag/v3.1.0
Bill
Tagaytay City, Philippines
