Extruder suddenly shifts to the right
Itamar
(@itamar)
Hello all!
I'm experiencing this issue when the extruder of my mk2s shifts all the way to the right side of the printer, then returns to a wrong position continuing to print. I went through all possible causes I found online but nothing really solved the issue.
Here is what I did.
1. Replaced X axis bearings and belt
2. Made sure belt is properly installed.
3. Motor screw is secured
4. Got everything lubricated properly
5. Re-calibrate xyz
I'm printing through USB using simplify3D and never had an issue.
I have tried multiple g-codes, all files behave the same, some prints were able to print successfully while the same files mostly failed.
Any ideas?
Many thanks!
This topic was modified 2 years temu by Itamar
Opublikowany : 26/08/2023 9:13 pm
Itamar
(@itamar)
RE: Extruder suddenly shifts to the right
Update
I have noticed that the printer is switching to silent mode mid print, printer settings was set to "auto mode". According to some online info silent mode is a possible cause for layer shifting since its reducing the stepper motor current, I have change the settings to "High mode" and will update soon hoping that the problem is solved.
Opublikowany : 27/08/2023 8:28 pm
sngx1275
(@sngx1275)
I recently discovered that you could change how loud it is.  So, I've been printing a bit in silent and auto and twice I've had layer shifts - well only once per print, but that's enough - shift was about 10mm each time.
Opublikowany : 22/09/2023 10:51 pm
