x-axis broken part
Itai Moscovitz
(@itai-moscovitz)
x-axis broken part
hi,
while i tried to insert the bearing to the X-end-motor in stage 4 of the X-axis assembly, it broke up 😥
i added a pic of the broken part.
1. is it possible to continue with the assembly while this part is broken? (the bearing sits ok in it)
2. where can i find the exact part (X-end-motor) stl to print? (the printer model is i3 MK2S)
i found the part in https://www.thingiverse.com/thing:865948 but it dosent look exactly the same.
that is pretty frustrating...
thenks for halpers
Opublikowany : 24/03/2018 7:08 pm
Olef
 Olef
(@olef)
Re: x-axis broken part
Here you go - https://www.prusa3d.com/prusa-i3-printable-parts/
Opublikowany : 24/03/2018 10:11 pm
Hi Itai,
you should get away with that, whilst you print another...
Opublikowany : 24/03/2018 11:04 pm
