Precise manual perpendicular xy axis calibration
Andreas Balogh
(@andreas-balogh)
I am always desperately disappointed when the printer's xyz calibration completes with: "slightly misaligned" or so, instead of "perfectly perpendicular". So here is a simple and effective way to get the headbed aligned 90 degrees to the frame.
  • Find a 30cm ruler and set it across the frame. Make sure the ruler touches the frame on both sides.
  • Move the heatbed to align one of the heatbed gridlines with the ruler.
  • Check and, if required, move the M10 nuts at the frame to slightly rotate the heatbed against the frame
  • Repeat until the heatbed gridline is perfectly aligned with the ruler.
  • The process assumes that the x-axis is aligned with the frame - and I think it should be. Even if the automatic xyz calibration now indicates a slight skew the ruler can be used as a reference for setting an angle between frame and y axis assembly.
    Corresponds to Step 31 of the Mk2S manual at https://manual.prusa3d.com/Guide/7.+PSU+&+Heatbed+assembly/297?lang=en .
    See also https://github.com/3d-gussner/Prusa-Firmware/wiki/How-to:-Get-hardware-as-accurate-as-possible%3F
    Posted : 25/08/2018 11:59 am
