Hyperfine bed leveling?
Seite 9 / 22
3d-gussner
(@3d-gussner)
Reputable Member Prusa-Translations
Re: Hyperfine bed leveling?
Is there a chance that the finer adjustment capability will be fed into a future release?
There are two pull request to get Hypefine tuning in the Prusa firmware, hopefully one get in:
https://github.com/prusa3d/Prusa-Firmware/pull/211
https://github.com/prusa3d/Prusa-Firmware/pull/220
Veröffentlicht : 10/10/2017 12:47 pm
PJR
 PJR
(@pjr)
Antient Member Moderator
Just a quick note to say a big THANK YOU for your work on this and to make one further suggestion:
One Z micro-step is 2.5 microns. Therefore, when saving the values in E^2, why not store the adjustment step count? This would allow an adjustment of up to ±250 microns (±100 steps) to be stored in a single byte.
On-screen adjustments would then be the same increment as that for "Live Z" (2.5 microns, truncating the .5 on display).
Peter
Veröffentlicht : 10/10/2017 1:19 pm
3d-gussner
(@3d-gussner)
No thank YOU and Jeff Jordan to make this possible! This all your idea, and i am just trying to get the code right.
Peter
That sound interesting. Did you check the pull request from Thess? He has a different approach storing the values.
BTW: I don't care if it is abc, d cntr e, fgh or something else, just needs to be easy to understand for everybody.
Veröffentlicht : 10/10/2017 1:48 pm
PJR
 PJR
(@pjr)
Not really, don't understand any of that stuff!
Doesn't matter how the points are organised; but I think the storage in E-Steps is the way to go, with G80 parameters in microns.
Peter
Veröffentlicht : 10/10/2017 2:18 pm
Nomad965
(@nomad965)
@JeffJordan
Would you be kind enough to post the stl files for the mini A-H squares please.
Thank you
Prusa i3 MK2s MK2.5s Mk3 Mk3s BearPrusa Zaribo 320 - Kit Build - Rc Driver - Tweak freak...
“I know nothing about surpassing others. I only know how to outdo myself.” -Bushido-
Veröffentlicht : 13/10/2017 1:06 am
3d-gussner
(@3d-gussner)
if somebody is interested in the firmware 3.1.0-RC1 including hyperfine bed calibration, filament runout sensor via LCD menu and some other mods/fixes, checkout https://github.com/3d-gussner/Prusa-Firmware/releases
Waldemar aka 3d-gussner
Veröffentlicht : 16/10/2017 4:35 pm
PJR
 PJR
(@pjr)
It seems as though the beds on my printers are getting old and becoming more variable due to heat cycling.
Printing calibration squares fairly regularly started to become somewhat tedious, so I wrote a non-printing calibration routine which requires either a 0.2mm feeler gauge or a double thickness sheet of copy paper...
The attached file simply heats the bed and nozzle and then moves the nozzle to all 9 probe points and pauses for measurement.
The results I obtained using this method were pretty accurate and only required a single calibration square print to confirm.
Please read the notes in the G-code file.
Peter
Veröffentlicht : 16/10/2017 5:38 pm
3d-gussner
(@3d-gussner)
Peter
Great Idea, thanks for sharing.
Using my feeler gauge (0.3,0.1,0.04,0.05,0.06,0.07,0.08,0.15,0.2mm) i can now measure all nine points and adjust the hyperfine values as a start point before using the hyperfine bed calibration g-code.
Veröffentlicht : 16/10/2017 6:10 pm
JeffJordan
(@jeffjordan)
Mitglied Moderator
💡 some people asked me about the single *.stl files to slice the little calibration squares themselves (e.g. for the use with other filament materials).
➡ so here they are, just for your convenience:
Veröffentlicht : 16/10/2017 10:37 pm
jacob.b9
(@jacob-b9)
Well... I know what I'm doing tonight...!
Thanks for everyone's hard work on this.
Veröffentlicht : 24/10/2017 8:45 pm
rich110
(@rich110)
This is exactly what I've been looking for - thanks PJR and JJ.
I mistakenly thought that the newer firmware 3.1.0-RC1 included this 9-point bed correction, so I went ahead and spent a day printing (and re-printing) all the circle and square calibration prints, working out my final values etc only to find that I still only had the old 4-point bed correction options.
@JeffJordan - are you able to PM me the recompiled firmware (HEX) with the 9-point calibration? Unfortunately I don't have enough thread replies to PM you myself.
Cheers,
Rich
Veröffentlicht : 29/10/2017 7:22 am
JeffJordan
(@jeffjordan)
Mitglied Moderator
3d-gussner has the 3.1.0-RC1 with hyperfine bed levelling online here.
Veröffentlicht : 29/10/2017 9:50 am
rich110
(@rich110)
Thank you. I must have D/Led the incorrect version of 3.1.0-RC1.
Cheers, Rich
Veröffentlicht : 29/10/2017 10:08 am
3d-gussner
(@3d-gussner)
Hi Richard,
what do you mean incorrect? i must have D/Led?
Waldemar
Veröffentlicht : 29/10/2017 1:16 pm
JeffJordan
(@jeffjordan)
Mitglied Moderator
...what do you mean incorrect? i must have D/Led?
guess D/Led = downloaded 🙄
Veröffentlicht : 29/10/2017 1:26 pm
3d-gussner
(@3d-gussner)
Okay, thanks
Veröffentlicht : 29/10/2017 1:28 pm
Sidbitters
(@sidbitters)
I have tried that link before and it just comes back to the same page. I used the chrome browser and edge and same thing. I also joined GitHub. I am not sure what my problem is.
edit: Ok, I believe I have here now.
Veröffentlicht : 29/10/2017 7:46 pm
rich110
(@rich110)
Hi Richard,
Waldemar
Hi, sorry for the confusion. In my previous post "incorrect" version meant a copy of the 3.1.0-RC1 firmware that did not have the 9-point hyperfine dbed correction settings (it only had the 4 L/R/F/B inputs). And "D/Led" meant downloaded.
Veröffentlicht : 30/10/2017 3:48 am
Sidbitters
(@sidbitters)
Anyone know what could be the cause of this error? The Prusa version loads fine and I've gone back and forth a few times.
Veröffentlicht : 31/10/2017 2:22 am
3d-gussner
(@3d-gussner)
Hi Ray,
which hex file did you try to upload and where exactly did you get it from?
Waldemar
Veröffentlicht : 31/10/2017 8:27 am
Seite 9 / 22
