Hyperfine bed leveling?
Seite 18 / 22
tuan.n2
(@tuan-n2)
Re: Hyperfine bed leveling?
I try to compile the hex file for my MK3 from the of 3.1.3 hyperfine source, but i notice it using 1_75mm_MK3-EINY04-E3Dv6full so i change it to 1_75mm_MK3-EINY10a-E3Dv6full by rename 1_75mm_MK3-EINY10a-E3Dv6full to Configuration_prusa.h in the variant folder and move it to Firmware but then i got the error from configuration.h. Should replace configuration.h in 3.1.3 hyperfine with the offical 3.1.3 configuration.h?
Arduino: 1.8.5 (Mac OS X), Board: "RAMBo"
/Applications/Arduino.app/Contents/Java/arduino-builder -dump-prefs -logger=machine -hardware /Applications/Arduino.app/Contents/Java/hardware -hardware /Users/TuanNguyen/Library/Arduino15/packages -tools /Applications/Arduino.app/Contents/Java/tools-builder -tools /Applications/Arduino.app/Contents/Java/hardware/tools/avr -tools /Users/TuanNguyen/Library/Arduino15/packages -built-in-libraries /Applications/Arduino.app/Contents/Java/libraries -libraries /Users/TuanNguyen/Documents/Arduino/libraries -fqbn=rambo:avr:rambo -ide-version=10805 -build-path /var/folders/ny/r49nk0bs6rlf83s0j2tzvt9m0000gn/T/arduino_build_9779 -warnings=none -build-cache /var/folders/ny/r49nk0bs6rlf83s0j2tzvt9m0000gn/T/arduino_cache_277093 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.avrdude.path=/Applications/Arduino.app/Contents/Java/hardware/tools/avr -prefs=runtime.tools.avr-gcc.path=/Applications/Arduino.app/Contents/Java/hardware/tools/avr -prefs=runtime.tools.arduinoOTA.path=/Applications/Arduino.app/Contents/Java/hardware/tools/avr -verbose /Users/TuanNguyen/Desktop/Prusa-Firmware-MK3-v3.1.3-HP/Firmware/Firmware.ino
/Applications/Arduino.app/Contents/Java/arduino-builder -compile -logger=machine -hardware /Applications/Arduino.app/Contents/Java/hardware -hardware /Users/TuanNguyen/Library/Arduino15/packages -tools /Applications/Arduino.app/Contents/Java/tools-builder -tools /Applications/Arduino.app/Contents/Java/hardware/tools/avr -tools /Users/TuanNguyen/Library/Arduino15/packages -built-in-libraries /Applications/Arduino.app/Contents/Java/libraries -libraries /Users/TuanNguyen/Documents/Arduino/libraries -fqbn=rambo:avr:rambo -ide-version=10805 -build-path /var/folders/ny/r49nk0bs6rlf83s0j2tzvt9m0000gn/T/arduino_build_9779 -warnings=none -build-cache /var/folders/ny/r49nk0bs6rlf83s0j2tzvt9m0000gn/T/arduino_cache_277093 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.avrdude.path=/Applications/Arduino.app/Contents/Java/hardware/tools/avr -prefs=runtime.tools.avr-gcc.path=/Applications/Arduino.app/Contents/Java/hardware/tools/avr -prefs=runtime.tools.arduinoOTA.path=/Applications/Arduino.app/Contents/Java/hardware/tools/avr -verbose /Users/TuanNguyen/Desktop/Prusa-Firmware-MK3-v3.1.3-HP/Firmware/Firmware.ino
Using board 'rambo' from platform in folder: /Users/TuanNguyen/Library/Arduino15/packages/rambo/hardware/avr/1.0.1
Using core 'arduino' from platform in folder: /Applications/Arduino.app/Contents/Java/hardware/arduino/avr
Detecting libraries used...
"/Applications/Arduino.app/Contents/Java/hardware/tools/avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -flto -w -x c++ -E -CC -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10805 -DARDUINO_AVR_RAMBO -DARDUINO_ARCH_AVR "-I/Applications/Arduino.app/Contents/Java/hardware/arduino/avr/cores/arduino" "-I/Users/TuanNguyen/Library/Arduino15/packages/rambo/hardware/avr/1.0.1/variants/rambo" "/var/folders/ny/r49nk0bs6rlf83s0j2tzvt9m0000gn/T/arduino_build_9779/sketch/Firmware.ino.cpp" -o "/dev/null"
"/Applications/Arduino.app/Contents/Java/hardware/tools/avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -flto -w -x c++ -E -CC -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10805 -DARDUINO_AVR_RAMBO -DARDUINO_ARCH_AVR "-I/Applications/Arduino.app/Contents/Java/hardware/arduino/avr/cores/arduino" "-I/Users/TuanNguyen/Library/Arduino15/packages/rambo/hardware/avr/1.0.1/variants/rambo" "/var/folders/ny/r49nk0bs6rlf83s0j2tzvt9m0000gn/T/arduino_build_9779/sketch/BlinkM.cpp" -o "/dev/null"
"/Applications/Arduino.app/Contents/Java/hardware/tools/avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -flto -w -x c++ -E -CC -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10805 -DARDUINO_AVR_RAMBO -DARDUINO_ARCH_AVR "-I/Applications/Arduino.app/Contents/Java/hardware/arduino/avr/cores/arduino" "-I/Users/TuanNguyen/Library/Arduino15/packages/rambo/hardware/avr/1.0.1/variants/rambo" "/var/folders/ny/r49nk0bs6rlf83s0j2tzvt9m0000gn/T/arduino_build_9779/sketch/ConfigurationStore.cpp" -o "/dev/null"
"/Applications/Arduino.app/Contents/Java/hardware/tools/avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -flto -w -x c++ -E -CC -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10805 -DARDUINO_AVR_RAMBO -DARDUINO_ARCH_AVR "-I/Applications/Arduino.app/Contents/Java/hardware/arduino/avr/cores/arduino" "-I/Users/TuanNguyen/Library/Arduino15/packages/rambo/hardware/avr/1.0.1/variants/rambo" "/var/folders/ny/r49nk0bs6rlf83s0j2tzvt9m0000gn/T/arduino_build_9779/sketch/Dcodes.cpp" -o "/dev/null"
"/Applications/Arduino.app/Contents/Java/hardware/tools/avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -flto -w -x c++ -E -CC -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10805 -DARDUINO_AVR_RAMBO -DARDUINO_ARCH_AVR "-I/Applications/Arduino.app/Contents/Java/hardware/arduino/avr/cores/arduino" "-I/Users/TuanNguyen/Library/Arduino15/packages/rambo/hardware/avr/1.0.1/variants/rambo" "/var/folders/ny/r49nk0bs6rlf83s0j2tzvt9m0000gn/T/arduino_build_9779/sketch/LiquidCrystal.cpp" -o "/dev/null"
"/Applications/Arduino.app/Contents/Java/hardware/tools/avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -flto -w -x c++ -E -CC -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10805 -DARDUINO_AVR_RAMBO -DARDUINO_ARCH_AVR "-I/Applications/Arduino.app/Contents/Java/hardware/arduino/avr/cores/arduino" "-I/Users/TuanNguyen/Library/Arduino15/packages/rambo/hardware/avr/1.0.1/variants/rambo" "/var/folders/ny/r49nk0bs6rlf83s0j2tzvt9m0000gn/T/arduino_build_9779/sketch/MarlinSerial.cpp" -o "/dev/null"
"/Applications/Arduino.app/Contents/Java/hardware/tools/avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -flto -w -x c++ -E -CC -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10805 -DARDUINO_AVR_RAMBO -DARDUINO_ARCH_AVR "-I/Applications/Arduino.app/Contents/Java/hardware/arduino/avr/cores/arduino" "-I/Users/TuanNguyen/Library/Arduino15/packages/rambo/hardware/avr/1.0.1/variants/rambo" "/var/folders/ny/r49nk0bs6rlf83s0j2tzvt9m0000gn/T/arduino_build_9779/sketch/Marlin_main.cpp" -o "/dev/null"
"/Applications/Arduino.app/Contents/Java/hardware/tools/avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -flto -w -x c++ -E -CC -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10805 -DARDUINO_AVR_RAMBO -DARDUINO_ARCH_AVR "-I/Applications/Arduino.app/Contents/Java/hardware/arduino/avr/cores/arduino" "-I/Users/TuanNguyen/Library/Arduino15/packages/rambo/hardware/avr/1.0.1/variants/rambo" "/var/folders/ny/r49nk0bs6rlf83s0j2tzvt9m0000gn/T/arduino_build_9779/sketch/Sd2Card.cpp" -o "/dev/null"
"/Applications/Arduino.app/Contents/Java/hardware/tools/avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -flto -w -x c++ -E -CC -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10805 -DARDUINO_AVR_RAMBO -DARDUINO_ARCH_AVR "-I/Applications/Arduino.app/Contents/Java/hardware/arduino/avr/cores/arduino" "-I/Users/TuanNguyen/Library/Arduino15/packages/rambo/hardware/avr/1.0.1/variants/rambo" "/var/folders/ny/r49nk0bs6rlf83s0j2tzvt9m0000gn/T/arduino_build_9779/sketch/SdBaseFile.cpp" -o "/dev/null"
"/Applications/Arduino.app/Contents/Java/hardware/tools/avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -flto -w -x c++ -E -CC -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10805 -DARDUINO_AVR_RAMBO -DARDUINO_ARCH_AVR "-I/Applications/Arduino.app/Contents/Java/hardware/arduino/avr/cores/arduino" "-I/Users/TuanNguyen/Library/Arduino15/packages/rambo/hardware/avr/1.0.1/variants/rambo" "/var/folders/ny/r49nk0bs6rlf83s0j2tzvt9m0000gn/T/arduino_build_9779/sketch/SdFatUtil.cpp" -o "/dev/null"
"/Applications/Arduino.app/Contents/Java/hardware/tools/avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -flto -w -x c++ -E -CC -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10805 -DARDUINO_AVR_RAMBO -DARDUINO_ARCH_AVR "-I/Applications/Arduino.app/Contents/Java/hardware/arduino/avr/cores/arduino" "-I/Users/TuanNguyen/Library/Arduino15/packages/rambo/hardware/avr/1.0.1/variants/rambo" "/var/folders/ny/r49nk0bs6rlf83s0j2tzvt9m0000gn/T/arduino_build_9779/sketch/SdFile.cpp" -o "/dev/null"
"/Applications/Arduino.app/Contents/Java/hardware/tools/avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -flto -w -x c++ -E -CC -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10805 -DARDUINO_AVR_RAMBO -DARDUINO_ARCH_AVR "-I/Applications/Arduino.app/Contents/Java/hardware/arduino/avr/cores/arduino" "-I/Users/TuanNguyen/Library/Arduino15/packages/rambo/hardware/avr/1.0.1/variants/rambo" "/var/folders/ny/r49nk0bs6rlf83s0j2tzvt9m0000gn/T/arduino_build_9779/sketch/SdVolume.cpp" -o "/dev/null"
"/Applications/Arduino.app/Contents/Java/hardware/tools/avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -flto -w -x c++ -E -CC -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10805 -DARDUINO_AVR_RAMBO -DARDUINO_ARCH_AVR "-I/Applications/Arduino.app/Contents/Java/hardware/arduino/avr/cores/arduino" "-I/Users/TuanNguyen/Library/Arduino15/packages/rambo/hardware/avr/1.0.1/variants/rambo" "/var/folders/ny/r49nk0bs6rlf83s0j2tzvt9m0000gn/T/arduino_build_9779/sketch/Servo.cpp" -o "/dev/null"
"/Applications/Arduino.app/Contents/Java/hardware/tools/avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -flto -w -x c++ -E -CC -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10805 -DARDUINO_AVR_RAMBO -DARDUINO_ARCH_AVR "-I/Applications/Arduino.app/Contents/Java/hardware/arduino/avr/cores/arduino" "-I/Users/TuanNguyen/Library/Arduino15/packages/rambo/hardware/avr/1.0.1/variants/rambo" "/var/folders/ny/r49nk0bs6rlf83s0j2tzvt9m0000gn/T/arduino_build_9779/sketch/adc.c" -o "/dev/null"
"/Applications/Arduino.app/Contents/Java/hardware/tools/avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -flto -w -x c++ -E -CC -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10805 -DARDUINO_AVR_RAMBO -DARDUINO_ARCH_AVR "-I/Applications/Arduino.app/Contents/Java/hardware/arduino/avr/cores/arduino" "-I/Users/TuanNguyen/Library/Arduino15/packages/rambo/hardware/avr/1.0.1/variants/rambo" "/var/folders/ny/r49nk0bs6rlf83s0j2tzvt9m0000gn/T/arduino_build_9779/sketch/cardreader.cpp" -o "/dev/null"
"/Applications/Arduino.app/Contents/Java/hardware/tools/avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -flto -w -x c++ -E -CC -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10805 -DARDUINO_AVR_RAMBO -DARDUINO_ARCH_AVR "-I/Applications/Arduino.app/Contents/Java/hardware/arduino/avr/cores/arduino" "-I/Users/TuanNguyen/Library/Arduino15/packages/rambo/hardware/avr/1.0.1/variants/rambo" "/var/folders/ny/r49nk0bs6rlf83s0j2tzvt9m0000gn/T/arduino_build_9779/sketch/cmdqueue.cpp" -o "/dev/null"
"/Applications/Arduino.app/Contents/Java/hardware/tools/avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -flto -w -x c++ -E -CC -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10805 -DARDUINO_AVR_RAMBO -DARDUINO_ARCH_AVR "-I/Applications/Arduino.app/Contents/Java/hardware/arduino/avr/cores/arduino" "-I/Users/TuanNguyen/Library/Arduino15/packages/rambo/hardware/avr/1.0.1/variants/rambo" "/var/folders/ny/r49nk0bs6rlf83s0j2tzvt9m0000gn/T/arduino_build_9779/sketch/digipot_mcp4451.cpp" -o "/dev/null"
"/Applications/Arduino.app/Contents/Java/hardware/tools/avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -flto -w -x c++ -E -CC -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10805 -DARDUINO_AVR_RAMBO -DARDUINO_ARCH_AVR "-I/Applications/Arduino.app/Contents/Java/hardware/arduino/avr/cores/arduino" "-I/Users/TuanNguyen/Library/Arduino15/packages/rambo/hardware/avr/1.0.1/variants/rambo" "/var/folders/ny/r49nk0bs6rlf83s0j2tzvt9m0000gn/T/arduino_build_9779/sketch/fsensor.cpp" -o "/dev/null"
"/Applications/Arduino.app/Contents/Java/hardware/tools/avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -flto -w -x c++ -E -CC -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10805 -DARDUINO_AVR_RAMBO -DARDUINO_ARCH_AVR "-I/Applications/Arduino.app/Contents/Java/hardware/arduino/avr/cores/arduino" "-I/Users/TuanNguyen/Library/Arduino15/packages/rambo/hardware/avr/1.0.1/variants/rambo" "/var/folders/ny/r49nk0bs6rlf83s0j2tzvt9m0000gn/T/arduino_build_9779/sketch/language_all.cpp" -o "/dev/null"
"/Applications/Arduino.app/Contents/Java/hardware/tools/avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -flto -w -x c++ -E -CC -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10805 -DARDUINO_AVR_RAMBO -DARDUINO_ARCH_AVR "-I/Applications/Arduino.app/Contents/Java/hardware/arduino/avr/cores/arduino" "-I/Users/TuanNguyen/Library/Arduino15/packages/rambo/hardware/avr/1.0.1/variants/rambo" "/var/folders/ny/r49nk0bs6rlf83s0j2tzvt9m0000gn/T/arduino_build_9779/sketch/mesh_bed_calibration.cpp" -o "/dev/null"
"/Applications/Arduino.app/Contents/Java/hardware/tools/avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -flto -w -x c++ -E -CC -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10805 -DARDUINO_AVR_RAMBO -DARDUINO_ARCH_AVR "-I/Applications/Arduino.app/Contents/Java/hardware/arduino/avr/cores/arduino" "-I/Users/TuanNguyen/Library/Arduino15/packages/rambo/hardware/avr/1.0.1/variants/rambo" "/var/folders/ny/r49nk0bs6rlf83s0j2tzvt9m0000gn/T/arduino_build_9779/sketch/mesh_bed_leveling.cpp" -o "/dev/null"
"/Applications/Arduino.app/Contents/Java/hardware/tools/avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -flto -w -x c++ -E -CC -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10805 -DARDUINO_AVR_RAMBO -DARDUINO_ARCH_AVR "-I/Applications/Arduino.app/Contents/Java/hardware/arduino/avr/cores/arduino" "-I/Users/TuanNguyen/Library/Arduino15/packages/rambo/hardware/avr/1.0.1/variants/rambo" "/var/folders/ny/r49nk0bs6rlf83s0j2tzvt9m0000gn/T/arduino_build_9779/sketch/motion_control.cpp" -o "/dev/null"
"/Applications/Arduino.app/Contents/Java/hardware/tools/avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -flto -w -x c++ -E -CC -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10805 -DARDUINO_AVR_RAMBO -DARDUINO_ARCH_AVR "-I/Applications/Arduino.app/Contents/Java/hardware/arduino/avr/cores/arduino" "-I/Users/TuanNguyen/Library/Arduino15/packages/rambo/hardware/avr/1.0.1/variants/rambo" "/var/folders/ny/r49nk0bs6rlf83s0j2tzvt9m0000gn/T/arduino_build_9779/sketch/pat9125.cpp" -o "/dev/null"
"/Applications/Arduino.app/Contents/Java/hardware/tools/avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -flto -w -x c++ -E -CC -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10805 -DARDUINO_AVR_RAMBO -DARDUINO_ARCH_AVR "-I/Applications/Arduino.app/Contents/Java/hardware/arduino/avr/cores/arduino" "-I/Users/TuanNguyen/Library/Arduino15/packages/rambo/hardware/avr/1.0.1/variants/rambo" "/var/folders/ny/r49nk0bs6rlf83s0j2tzvt9m0000gn/T/arduino_build_9779/sketch/planner.cpp" -o "/dev/null"
"/Applications/Arduino.app/Contents/Java/hardware/tools/avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -flto -w -x c++ -E -CC -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10805 -DARDUINO_AVR_RAMBO -DARDUINO_ARCH_AVR "-I/Applications/Arduino.app/Contents/Java/hardware/arduino/avr/cores/arduino" "-I/Users/TuanNguyen/Library/Arduino15/packages/rambo/hardware/avr/1.0.1/variants/rambo" "/var/folders/ny/r49nk0bs6rlf83s0j2tzvt9m0000gn/T/arduino_build_9779/sketch/qr_solve.cpp" -o "/dev/null"
"/Applications/Arduino.app/Contents/Java/hardware/tools/avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -flto -w -x c++ -E -CC -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10805 -DARDUINO_AVR_RAMBO -DARDUINO_ARCH_AVR "-I/Applications/Arduino.app/Contents/Java/hardware/arduino/avr/cores/arduino" "-I/Users/TuanNguyen/Library/Arduino15/packages/rambo/hardware/avr/1.0.1/variants/rambo" "/var/folders/ny/r49nk0bs6rlf83s0j2tzvt9m0000gn/T/arduino_build_9779/sketch/stepper.cpp" -o "/dev/null"
"/Applications/Arduino.app/Contents/Java/hardware/tools/avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -flto -w -x c++ -E -CC -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10805 -DARDUINO_AVR_RAMBO -DARDUINO_ARCH_AVR "-I/Applications/Arduino.app/Contents/Java/hardware/arduino/avr/cores/arduino" "-I/Users/TuanNguyen/Library/Arduino15/packages/rambo/hardware/avr/1.0.1/variants/rambo" "/var/folders/ny/r49nk0bs6rlf83s0j2tzvt9m0000gn/T/arduino_build_9779/sketch/swi2c.cpp" -o "/dev/null"
"/Applications/Arduino.app/Contents/Java/hardware/tools/avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -flto -w -x c++ -E -CC -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10805 -DARDUINO_AVR_RAMBO -DARDUINO_ARCH_AVR "-I/Applications/Arduino.app/Contents/Java/hardware/arduino/avr/cores/arduino" "-I/Users/TuanNguyen/Library/Arduino15/packages/rambo/hardware/avr/1.0.1/variants/rambo" "/var/folders/ny/r49nk0bs6rlf83s0j2tzvt9m0000gn/T/arduino_build_9779/sketch/swspi.cpp" -o "/dev/null"
"/Applications/Arduino.app/Contents/Java/hardware/tools/avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -flto -w -x c++ -E -CC -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10805 -DARDUINO_AVR_RAMBO -DARDUINO_ARCH_AVR "-I/Applications/Arduino.app/Contents/Java/hardware/arduino/avr/cores/arduino" "-I/Users/TuanNguyen/Library/Arduino15/packages/rambo/hardware/avr/1.0.1/variants/rambo" "/var/folders/ny/r49nk0bs6rlf83s0j2tzvt9m0000gn/T/arduino_build_9779/sketch/temperature.cpp" -o "/dev/null"
"/Applications/Arduino.app/Contents/Java/hardware/tools/avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -flto -w -x c++ -E -CC -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10805 -DARDUINO_AVR_RAMBO -DARDUINO_ARCH_AVR "-I/Applications/Arduino.app/Contents/Java/hardware/arduino/avr/cores/arduino" "-I/Users/TuanNguyen/Library/Arduino15/packages/rambo/hardware/avr/1.0.1/variants/rambo" "/var/folders/ny/r49nk0bs6rlf83s0j2tzvt9m0000gn/T/arduino_build_9779/sketch/tmc2130.cpp" -o "/dev/null"
"/Applications/Arduino.app/Contents/Java/hardware/tools/avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -flto -w -x c++ -E -CC -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10805 -DARDUINO_AVR_RAMBO -DARDUINO_ARCH_AVR "-I/Applications/Arduino.app/Contents/Java/hardware/arduino/avr/cores/arduino" "-I/Users/TuanNguyen/Library/Arduino15/packages/rambo/hardware/avr/1.0.1/variants/rambo" "/var/folders/ny/r49nk0bs6rlf83s0j2tzvt9m0000gn/T/arduino_build_9779/sketch/ultralcd.cpp" -o "/dev/null"
"/Applications/Arduino.app/Contents/Java/hardware/tools/avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -flto -w -x c++ -E -CC -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10805 -DARDUINO_AVR_RAMBO -DARDUINO_ARCH_AVR "-I/Applications/Arduino.app/Contents/Java/hardware/arduino/avr/cores/arduino" "-I/Users/TuanNguyen/Library/Arduino15/packages/rambo/hardware/avr/1.0.1/variants/rambo" "/var/folders/ny/r49nk0bs6rlf83s0j2tzvt9m0000gn/T/arduino_build_9779/sketch/util.cpp" -o "/dev/null"
"/Applications/Arduino.app/Contents/Java/hardware/tools/avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -flto -w -x c++ -E -CC -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10805 -DARDUINO_AVR_RAMBO -DARDUINO_ARCH_AVR "-I/Applications/Arduino.app/Contents/Java/hardware/arduino/avr/cores/arduino" "-I/Users/TuanNguyen/Library/Arduino15/packages/rambo/hardware/avr/1.0.1/variants/rambo" "/var/folders/ny/r49nk0bs6rlf83s0j2tzvt9m0000gn/T/arduino_build_9779/sketch/vector_3.cpp" -o "/dev/null"
"/Applications/Arduino.app/Contents/Java/hardware/tools/avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -flto -w -x c++ -E -CC -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10805 -DARDUINO_AVR_RAMBO -DARDUINO_ARCH_AVR "-I/Applications/Arduino.app/Contents/Java/hardware/arduino/avr/cores/arduino" "-I/Users/TuanNguyen/Library/Arduino15/packages/rambo/hardware/avr/1.0.1/variants/rambo" "/var/folders/ny/r49nk0bs6rlf83s0j2tzvt9m0000gn/T/arduino_build_9779/sketch/watchdog.cpp" -o "/dev/null"
Generating function prototypes...
"/Applications/Arduino.app/Contents/Java/hardware/tools/avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -flto -w -x c++ -E -CC -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10805 -DARDUINO_AVR_RAMBO -DARDUINO_ARCH_AVR "-I/Applications/Arduino.app/Contents/Java/hardware/arduino/avr/cores/arduino" "-I/Users/TuanNguyen/Library/Arduino15/packages/rambo/hardware/avr/1.0.1/variants/rambo" "/var/folders/ny/r49nk0bs6rlf83s0j2tzvt9m0000gn/T/arduino_build_9779/sketch/Firmware.ino.cpp" -o "/var/folders/ny/r49nk0bs6rlf83s0j2tzvt9m0000gn/T/arduino_build_9779/preproc/ctags_target_for_gcc_minus_e.cpp"
In file included from /var/folders/ny/r49nk0bs6rlf83s0j2tzvt9m0000gn/T/arduino_build_9779/sketch/Marlin.h:23:0,
from /var/folders/ny/r49nk0bs6rlf83s0j2tzvt9m0000gn/T/arduino_build_9779/sketch/thermistortables.h:4,
from /var/folders/ny/r49nk0bs6rlf83s0j2tzvt9m0000gn/T/arduino_build_9779/sketch/Configuration.h:868,
from /Users/TuanNguyen/Desktop/Prusa-Firmware-MK3-v3.1.3-HP/Firmware/Firmware.ino:33:
pins.h:51: error: #error Unknown MOTHERBOARD value in configuration.h
exit status 1
Veröffentlicht : 19/04/2018 7:01 am
3d-gussner
(@3d-gussner)
Reputable Member Prusa-Translations
it would be better if you could post that kind of compiling errors as an issue in Github https://github.com/3d-gussner/Prusa-Firmware/issues .
The issue you have is that Prusa compiled their firmware with the Configuration_prusa.h file which had been updated few times.
The '1_75mm_MK3-EINY10a-E3Dv6full.h' in that release is 'out-datet' just few days ago Prusa updatet these files in the 3.2.0-RC1 release.
As you can see in the Prusa github there are now only 3 variants for the MK2, MK2.5 and MK3.
You don't need to change the Configuration_prusa.h file in the 3.1.3 release. Future releases will be matching the original firmware as they always did.
Veröffentlicht : 19/04/2018 11:05 am
joshua.w6
(@joshua-w6)
Tried getting this working with MK3 3.2.0-RC1, but I ran into an issue when trying to get it working (conflict which I do not have the skills to overcome)
Anyone want to help me accomplish the goal of getting hyperfine working on 3.2.0-RC1?
Also / Alternatively, can someone point out to me where the 50um/-50um manually adjust bed limits are in the firmware files so I can increase it prior to compiling?
Veröffentlicht : 20/04/2018 7:57 am
3d-gussner
(@3d-gussner)
Hi Joshua,
Can you post the error on the github https://github.com/3d-gussner/Prusa-Firmware/issues or if it is stock firmware check https://github.com/prusa3d/Prusa-Firmware/issues ?
I stopped to merge Hyperfine to 3.2.0-RC1 due to many bugs and issues has been reported in the origin. As soon most critical issues are solved, i will catch up with it.
If you want to get into that:
- try to compare the source.zip files, I use WinMerge (compare all files) and Notepad++ (compare one file). You also can use Github 'compare' between different branches. So you can see what is changed.
- Read the Github issues and pull request sections, as there is a bug preventing to compile 3.2.0-RC1
The limit is in 'ultralcd.cpp' look for '#define BED_ADJUSTMENT_UM_MAX 50'. The max you should go is 127 as you need a range from -127 to +128
I am busy to change it so that larger values are possible without changing the EEPROM space...takes bit time to code and even more time to test it on my MK2.
BTW: If you switch from any Hyperfine Bed Leveling firmware to stock or update or downgrade the firmware. Please reset the Bed Level Correct values, as there is a chance that EEPROM space being used by Hyperfine Bed Leveling is used by the new firmware by another function.
Veröffentlicht : 20/04/2018 9:10 am
joshua.w6
(@joshua-w6)
Thanks! This is super helpful.
The error I experienced wasn't with Hyperfine, it's with my lack of knowledge of git/github. I was trying to implement hyperfine to the 3.2.0-RC1, but as it had conflicts, wasn't a straight merge, I decided not to proceed any further.
Of all the things in your note, I'm particularly happy to learn about Winmerge. The knowledge of it has just saved me a massive amount of time learning git when it's not really my thing. (3d printing is right up my alley, git, is a lesson for another day)
Seriously, you've saved me a ton of time, I'm super grateful, thank you!
Veröffentlicht : 21/04/2018 1:59 am
Martin
(@martin-15)
I posted a month or so ago and asked if the hyper bed levelling firmware would work with the MK2.5 upgrade. The developer had mention they had hoped to have MK2.5 implemented within firmware V3.1.3. My kit has now shipped and i've just check github and noted a pre-release firmware MK3: 3.1.3 firmware for Prusa i3 MK3 + Hyperfine Bed Leveling + PINDA-Fix. I cannot see any mentions that this work for the MK2.5 upgrade and was wondering if it has been implemented within this version or not (i appreciate it is a pre-release so may have some quirks still)?
As always i'm really appreciative of the hard work everyone puts in to create this firmware (hope prusa implements into stock firmware at some point).
Veröffentlicht : 16/05/2018 11:51 pm
3d-gussner
(@3d-gussner)
Hi Martin,
I leave it as pre-release until get few feedback that if it works as I don't own a MK2.5 and so can't test it myself.
As the fw 3.2.0 seams to be stable I will try to get Hyperfine bed leveling into it. This will be again a pre-release until I get some feedback from users. Hope my Mk3 comes soon so I can test at least the mk2 and mk3 builds myself.
Veröffentlicht : 17/05/2018 12:05 am
3d-gussner
(@3d-gussner)
Also asked for some results of users to try to convince Prusa to get it in their firmware. It is something else if one person asks for implementing or lot. Maybe I have to try again but Prusa was/is so busy fixing the firmware chances are small if I do it on my own.
Veröffentlicht : 17/05/2018 12:13 am
ron
 ron
(@ron)
I mentionned it in my answer to prusa survey.
Veröffentlicht : 18/05/2018 8:42 pm
3d-gussner
(@3d-gussner)
Thanks, would great if they consider it.
Veröffentlicht : 18/05/2018 10:02 pm
ron
 ron
(@ron)
That is me thanking you. I prefer to print bed full of small parts or large parts on my mk2s with your firmware than on my mk3 with stock firmware.
As prusa don't consider this properly at the moment, i think i will go the Brigandier's way by machanicaly adjust the level.
Veröffentlicht : 18/05/2018 10:57 pm
3d-gussner
(@3d-gussner)
I am only the guy who tries to keep that feature up2date. All work was done by PJR and JeffJordan.
Started a wiki on my github https://github.com/3d-gussner/Prusa-Firmware/wiki/Hyperfine-Bed-Leveling ... Need more time to finish it as it has at this moment the hardware side...need to write the firmware/soft part 🙂
There are Hyperfine firmware for MK2.5, MK3 and MK2MMU as well.
Had few MK3 owners who got better results than with stock firmware.
Veröffentlicht : 18/05/2018 11:13 pm
jason.c35
(@jason-c35)
Hi, I've been trying to work around the modified version of the prusa mk2.
I read that the maximum microns on G80 is +-200, is there a way to increment it? If I can, in what place of the code can I change it?
I find that I need around 220 on one of my points.
I download the latest firmware from gussner.
Thank You!
Veröffentlicht : 20/05/2018 10:03 am
3d-gussner
(@3d-gussner)
Thank You!
Hi Jason,
I pushed the max. from 100 to 200 as there were some requests. I think that a bed that badly warped should be replaced by Prusa.
Before to claim a replacement you should read https://github.com/3d-gussner/Prusa-Firmware/wiki/Hyperfine-Bed-Leveling as quite often it isn't the bed PCB warped that bad, it is/are more the build or small parts.
220 is a quite high value, please check if your bed/build is hardware wise 'flat'?
Few users reported that getting the bed hardware wise as 'flat' as possible made the hyperfine bed leveling easier with much lower values needed.
But you can find the limit it in the Marlin_main.cpp
if (correction == 0)
continue;
float offset = float(correction) * 0.001f;
if (fabs(offset) > 0.201f)
and change it to
continue;
if (fabs(offset) > 0.221f)
so get max at 220.
Hope that helps.
Veröffentlicht : 20/05/2018 11:17 am
jason.c35
(@jason-c35)
Thank You!
Hi Jason,
continue;
and change it to
continue;
so get max at 220.
Hope that helps.
Hi Waldemar,
I download the code form the tag v3.1.0-001-HFM ( https://github.com/3d-gussner/Prusa-Firmware/tree/v3.1.0-001-HFM ), but I get a compilation/update error:
avrdude: verification error, firs mismatch at bute 0x3c000
0x18 != 0x7c
avrdude: verification error; content mismatch
Did I copy something wrong:?: ❓ I tried to uploaded with any modification and I get the same result.
Thank You!
Veröffentlicht : 21/05/2018 8:25 am
3d-gussner
(@3d-gussner)
Thank You!
Hi Jason,
continue;
and change it to
continue;
so get max at 220.
Hope that helps.
Hi Waldemar,
0x18 != 0x7c
Thank You!
Best is to download the source.zip from the releases as this are fixed. Sorry I have few branches but most resent are the -private_build and I use these to compile. Did you read my build.me ?
Veröffentlicht : 21/05/2018 11:09 am
ron
 ron
(@ron)
But as i know, not with Linear Advance that I can't live with. 😉
Veröffentlicht : 22/05/2018 12:43 am
jason.c35
(@jason-c35)
Hi Jason,
continue;
and change it to
continue;
so get max at 220.
Hope that helps.
Hi Waldemar,
0x18 != 0x7c
Thank You!
Thank You Waldemar,
I think I scrolled to fast that I did not see that there is a sourcode.zip on the releases. I will check it. 😀 😀 😀 😀
Veröffentlicht : 22/05/2018 1:44 am
3d-gussner
(@3d-gussner)
Hi Ron,
Firmware 3.2.1 is available and I will merge Hyperfine Bed Leveling in the next days. This firmware version has LAv1 activated.
Veröffentlicht : 22/05/2018 6:54 am
jason.c35
(@jason-c35)
Hi Waldemar,
I tried with the source code on the release page but I still get this,
WARNING: Category '' in library Wire is not valid. Setting to 'Uncategorized'
Sketch uses 255,816 bytes (99%) of program storage space. Maximum is 258,048 bytes.
Global variables use 6,104 bytes of dynamic memory.
avrdude: verification error, first mismatch at byte 0x3c000
0x00 != 0x7c
I don't know what is going on with that 🙁 🙁 😕
Is there a way that you can send me a modified hex with a maximun of 300 on G80??
Thanks!
Veröffentlicht : 22/05/2018 7:53 am
Seite 18 / 22
