Filament can't be unloaded
renee.t
(@renee-t)
Hi all,
I was trying to unload some PLA filament to change colours, but the unloading didn't work, even when pulling pretty hard.
I proceeded to remove the tension screws and open the door next to the extruder. There were some small sawdust like flakes, which I brushed away. However, there is no sign of a clog there (the filament extends downwards into the white PTFE tube).
After this I tried to heat the nozzle to 260 degrees Celcius and manually push the filament out, but no filament oozed out of the bottom. While it was at 260, I inserted the given hypodermic needle into the nozzle from the bottom. It goes pretty much the entire way in.
I'm very confused now; and now I have a length of filament sticking out the top of the extruder that seems determined not to go anywhere any time soon. Also, because the filament is still stuck inside, I can't exactly jam a wire or other implement down the filament tube, as other posts I've read have suggested.
Do I have to disassemble the entire hotend? Please help!
Este debate ha sido modificado el hace 6 years por renee.t
Respondido : 13/02/2020 4:22 pm
