					                		3mm filament for stiffening wire harness - Assembly and first prints troubleshooting                                    </title>
                <link>https://forum.prusa3d.com/forum/original-prusa-i3-mk2-s-assembly-and-first-prints-troubleshooting/3mm-filament-for-stiffening-wire-harness/</link>
                <lastBuildDate>Fri, 17 Apr 2026 00:13:23 +0000</lastBuildDate>
                        <title>RE: 3mm filament for stiffening wire harness</title>
                        <link>https://forum.prusa3d.com/forum/original-prusa-i3-mk2-s-assembly-and-first-prints-troubleshooting/3mm-filament-for-stiffening-wire-harness/#post-661450</link>
                        <pubDate>Sat, 24 Jun 2023 16:37:23 +0000</pubDate>
                        <description><![CDATA[3mm nylon strimmer cord works!I have also stuffed an longM3 Screw up 4mm PTFE Tube, cut the head off the screw and put the stub of the screw into the 3mm hole for the support filament,the PT...]]></description>
                        <content:encoded><![CDATA[<p>3mm nylon strimmer cord works!<br />I have also stuffed an longM3 Screw up 4mm PTFE Tube, cut the head off the screw and put the stub of the screw into the 3mm hole for the support filament,the PTFE makes a good support filament<br /><br />Regards Joan</p>]]></content:encoded>
                        <category domain="https://forum.prusa3d.com/forum/original-prusa-i3-mk2-s-assembly-and-first-prints-troubleshooting/">Assembly and first prints troubleshooting</category>                        <dc:creator>JoanTabb</dc:creator>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/original-prusa-i3-mk2-s-assembly-and-first-prints-troubleshooting/3mm-filament-for-stiffening-wire-harness/#post-661450</guid>
                        <link>https://forum.prusa3d.com/forum/original-prusa-i3-mk2-s-assembly-and-first-prints-troubleshooting/3mm-filament-for-stiffening-wire-harness/#post-607133</link>
                        <pubDate>Tue, 17 May 2022 00:12:36 +0000</pubDate>
                        <content:encoded><![CDATA[<p>https://www.partsbuilt.com/3mm-filament-for-prusa-wiring-harness-support/</p>]]></content:encoded>
                        <category domain="https://forum.prusa3d.com/forum/original-prusa-i3-mk2-s-assembly-and-first-prints-troubleshooting/">Assembly and first prints troubleshooting</category>                        <dc:creator>Netpackrat</dc:creator>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/original-prusa-i3-mk2-s-assembly-and-first-prints-troubleshooting/3mm-filament-for-stiffening-wire-harness/#post-607133</guid>
                        <link>https://forum.prusa3d.com/forum/original-prusa-i3-mk2-s-assembly-and-first-prints-troubleshooting/3mm-filament-for-stiffening-wire-harness/#post-580402</link>
                        <pubDate>Tue, 15 Feb 2022 01:32:01 +0000</pubDate>
                        <description><![CDATA[Go to eBay or a eshop and buy a sample of nylon 3mm filament.]]></description>
                        <content:encoded><![CDATA[<p>Go to eBay or a eshop and buy a sample of nylon 3mm filament.  </p>]]></content:encoded>
                        <category domain="https://forum.prusa3d.com/forum/original-prusa-i3-mk2-s-assembly-and-first-prints-troubleshooting/">Assembly and first prints troubleshooting</category>                        <dc:creator>cwbullet</dc:creator>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/original-prusa-i3-mk2-s-assembly-and-first-prints-troubleshooting/3mm-filament-for-stiffening-wire-harness/#post-580402</guid>
                        <title>3mm filament for stiffening wire harness</title>
                        <link>https://forum.prusa3d.com/forum/original-prusa-i3-mk2-s-assembly-and-first-prints-troubleshooting/3mm-filament-for-stiffening-wire-harness/#post-579715</link>
                        <pubDate>Sun, 13 Feb 2022 18:49:45 +0000</pubDate>
                        <description><![CDATA[Does anyone have a good source for a small amount of the 3mm filament used to stiffen the wire harness running from the print head to the controller?  I am rebuilding a printer and the prior...]]></description>
                        <content:encoded><![CDATA[<p>Does anyone have a good source for a small amount of the 3mm filament used to stiffen the wire harness running from the print head to the controller?  I am rebuilding a printer and the prior owner had pulled it out and had taped the wire harness to the top of the frame.</p><p>P. Todd</p>]]></content:encoded>
                        <category domain="https://forum.prusa3d.com/forum/original-prusa-i3-mk2-s-assembly-and-first-prints-troubleshooting/">Assembly and first prints troubleshooting</category>                        <dc:creator>Todd Decker</dc:creator>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/original-prusa-i3-mk2-s-assembly-and-first-prints-troubleshooting/3mm-filament-for-stiffening-wire-harness/#post-579715</guid>
