Finished print song?
Hi guys, I wanted the printer to make some sort of tone when the print completed. Then thought, "why not something fun?".
; Play Classical.
M300 S659.255 P125 ; Play E5 for 4th.
M300 S622.254 P125 ; Play Eb5 for 4th.
M300 S493.883 P125 ; Play B4 for 4th.
M300 S587.33 P125 ; Play D5 for 4th.
M300 S523.251 P125 ; Play C5 for 4th.
M300 S440 P500 ; Play A4 for Whole.
; Play Batman Theme
M300 S440 P125 ; Play A4 for 4th.
M300 S261.626 P125 ; Play C4 for 4th.
M300 S698.456 P500 ; Play F5 for Whole.
M300 S659.255 P250 ; Play E5 for 2nd.
G4 P500 ; Pause for Whole.
M300 S659.255 P500 ; Play E5 for Whole.
M300 S739.989 P500 ; Play Gb5 for Whole.
M300 S783.991 P250 ; Play G5 for 2nd.
; Play Ghostbusters Theme
M300 S987.767 P125 ; Play B5 for 4th.
M300 S1244.51 P250 ; Play Eb6 for 2nd.
M300 S987.767 P250 ; Play B5 for 2nd.
M300 S1108.73 P250 ; Play Db6 for 2nd.
M300 S880 P250 ; Play A5 for 2nd.
G4 P250 ; Pause for 2nd.
; Play Imperial March
M300 S195.998 P250 ; Play G3 for 2nd.
M300 S155.563 P125 ; Play Eb3 for 4th.
G4 P62.5 ; Pause for 8th.
M300 S233.082 P62.5 ; Play Bb3 for 8th.
M300 S195.998 P500 ; Play G3 for Whole.
M300 S293.665 P250 ; Play D4 for 2nd.
M300 S311.127 P125 ; Play Eb4 for 4th.
M300 S246.942 P62.5 ; Play B3 for 8th.
M300 S184.997 P250 ; Play Gb3 for 2nd.
MK2S kit owner since 8/15/2017
Re: Finished print song?
Thomas
Nice!
where do i put this into
If those are too silly for you, I use:
; PLAY CHIME
M300 S1046.5 P100 ; Play C6
M300 S1174.7 P100 ; Play D6
M300 S1318.5 P100 ; Play E6
M300 S1396.9 P100 ; Play F6
Just for clarification... If I'm reading the image correctly, insert the code before disabling motors(?)
That's "MISTER Old Fart" to you!
Do you want the motors to release before or after the song? I wanted it before. Doesn't really matter.
When I asked the question, it wasn't clear to me what hardware component was making the "song".
At the risk of dating myself, back in the days of the Commodore 64, some folks figured out how to get their 1541 disc drive to play, "Bicycle Built for Two" (and other ditties...) You may have to crank up the volume to hear it, but live--at the time--it was quite audible.
From context, I gather the songs played by the printer have another means for producing the tones.
That would be a fun project too but no heroic tinkering is needed to have an end-of-print chime. Just the M300 buzzer/beeper control command (see code).
Here are some more
;Auld Lang Syne
M300 S 578 P 800
M300 S 783 P 1200
M300 S 783 P 400
M300 S 783 P 800
M300 S 987 P 800
M300 S 880 P 1200
M300 S 783 P 400
M300 S 880 P 800
M300 S 987 P 800
M300 S 783 P 1200
M300 S 783 P 400
M300 S 987 P 800
M300 S 1174 P 800
M300 S 1318 P 1600
;Bethoven
M300 S988 P400
M300 S988 P400
M300 S1047 P400
M300 S1175 P400
M300 S1175 P400
M300 S1047 P400
M300 S988 P400
M300 S880 P400
M300 S784 P400
M300 S784 P400
M300 S880 P400
M300 S988 P400
M300 S988 P600
M300 S880 P200
M300 S880 P800
;MacGyver
M300 S 1046 P 233
M300 S 1046 P 233
M300 S 1046 P 233
M300 S 1046 P 200
M300 S 1046 P 200
M300 S 1046 P 200
M300 S 987 P 800
M300 S 1396 P 200
M300 S 880 P 400
M300 S 783 P 1000
M300 S 1046 P 200
M300 S 1046 P 400
M300 S 987 P 400
M300 S 1046 P 200
M300 S 987 P 200
M300 S 880 P 200
M300 S 783 P 400
M300 S 1318 P 400
M300 S 783 P 800
;Super Mario
M300 S 1318 P 200
M300 S 1318 P 200
M300 S 0 P 200
M300 S 1318 P 200
M300 S 0 P 200
M300 S 1046 P 200
M300 S 1318 P 400
M300 S 1567 P 400
M300 S 0 P 400
M300 S 783 P 400
M300 S 0 P 400
M300 S 1567 P 400
M300 S 0 P 200
M300 S 783 P 200
M300 S 0 P 200
M300 S 659 P 400
M300 S 0 P 200
M300 S 880 P 200
M300 S 0 P 200
M300 S 987 P 200
M300 S 0 P 200
M300 S 925 P 200
M300 S 880 P 400
M300 S 783 P 300
M300 S 1318 P 300
M300 S 1567 P 300
M300 S 1760 P 400
M300 S 1396 P 200
M300 S 1567 P 200
M300 S 0 P 200
M300 S 1318 P 200
M300 S 0 P 200
M300 S 1046 P 200
M300 S 1174 P 200
M300 S 987 P 200
Think you could figure out the Final Fantasy VII victory song?
Novelty songs played at high volume on a piezo buzzer are interesting once. Maybe twice. After that, I want a minimal chirp to announce the job is done.
Actually once the printer gets quiet, this is a real good indicator for me 😀
Often linked posts:
Going small with MMU2
Real Multi Material
My prints on Instagram
Final Countdown by Europe?
We're usually watching a movie in an adjoining room while the printer does its thing. The beep isn't loud or long enough to hear/discern over the soundtrack, so I find myself squinting every once in a while to see if there's any movement in the spool. (I hate having the spool on top of the printer, but until the MMU gets here and I can set both up properly in my office closet...)
So the little ditties would be helpful for us... if I could remember to paste them onto the gcode! 😳
I'm usually so stoked about having a file ready to print that I forget all about the tunes in the rush to print.
(Now if I could find one that played Foggy Mountain Breakdown, things might be different...) 😀
RE: Finished print song?
Thank you. Fantastic (and fun) idea for noisy environments.
I'm trying to this with my Mk3S and I'm having some issues. Whenever I try to play a song it only produces 1 frequency. There are brief pauses between gcode lines and when I set the frequency to 0, but that's it. Is there a firmware setting or a setting in the lcd menu that I need to enable to get different frequencies?
Good. Thank you much. 1 great idea
I wonder if you could play Chopin - Funeral March if the print crashes or fails 😀
@msb64x
I think I read in the latest firmware RC that the feature to play notes had been fixed. Maybe making it up, I am very old and doddery.
