Ver 2.3.0 Install with macOS Big Sur Issue
RE: Ver 2.3.0 Install with macOS Big Sur Issue
So I don't understand what happened to my post? It's here...but blank?
Ok, try again.... I downloaded the Ver 2.3.0 software and started the install. Then I got a popup (see attached) that states Pronterface 32bit is not supported on macOS Catalina 10.15 and newer. Should I just ignore the message and continue or is there a different version I should be installing?
Thanks!
Michael
@michael-42
I would ignore it and see if it works.
Thanks Chuck! I'll give it a go as soon as I get some relief from work. Been too busy....
@michael-42
Pronterface in the 2.3.0 package did not work for me (macOS Big Sur version 11.2.1). Just downloaded the Pronterface 2.0.0rc8 release from GitHub though and it worked for me. https://github.com/kliment/Printrun/releases
