sd card slot loose? card reloads randomly at times
coopster
(@coopster)
the sd card slot is either worn or  connection is loose...sometimes the card reloads randomily  ...ive even thad this happened during a print … which of course will ruin the print job because the printer will stop.
im going to try a new sd card in the mean time to see if this solves the problem
Posted : 16/12/2019 12:10 am
coopster
(@coopster)
RE: sd card slot loose? card reloads randomly at times
i replaced the sd card and no luck.    I think there is a problem with the board /and or reader .   I also have these problems with the printer
 constant min temp error at startup
auto filament sensor not working
random reloading or card removed while in the middle of printing , as you can see by the pictures below ,  the description goes blank,  then it shows card removed or no sd card
Posted : 05/01/2020 7:40 pm
