					                		Rotary knob not responding - Hardware, firmware and software help                                    </title>
                <link>https://forum.prusa3d.com/forum/original-prusa-i3-mk2-5s-mk2-5-hardware-firmware-and-software-help/rotary-knob-not-responding/</link>
                <lastBuildDate>Wed, 15 Apr 2026 04:32:18 +0000</lastBuildDate>
                        <link>https://forum.prusa3d.com/forum/original-prusa-i3-mk2-5s-mk2-5-hardware-firmware-and-software-help/rotary-knob-not-responding/#post-720915</link>
                        <pubDate>Thu, 05 Sep 2024 00:49:56 +0000</pubDate>
                        <description><![CDATA[If you have it, the first thing to try is a quick blast of switch-cleaner.After that check for broken solder connections on the part - you can also try faking pulses by dabbing with a probe ...]]></description>
                        <content:encoded><![CDATA[<p>If you have it, the first thing to try is a quick blast of switch-cleaner.</p><p>After that check for broken solder connections on the part - you can also try faking pulses by dabbing with a probe - are you confident with a soldering iron?</p><p>Cheerio,</p>]]></content:encoded>
                        <category domain="https://forum.prusa3d.com/forum/original-prusa-i3-mk2-5s-mk2-5-hardware-firmware-and-software-help/">Hardware, firmware and software help</category>                        <dc:creator>Diem</dc:creator>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/original-prusa-i3-mk2-5s-mk2-5-hardware-firmware-and-software-help/rotary-knob-not-responding/#post-720915</guid>
                        <title>Rotary knob not responding</title>
                        <link>https://forum.prusa3d.com/forum/original-prusa-i3-mk2-5s-mk2-5-hardware-firmware-and-software-help/rotary-knob-not-responding/#post-720910</link>
                        <pubDate>Wed, 04 Sep 2024 22:00:03 +0000</pubDate>
                        <description><![CDATA[Hello! Last night I started a print and woke up to a nice blob of plastic after the part broke off and stuck to the extruder.  I went to restart everything and get it cleaned up and noticed ...]]></description>
                        <content:encoded><![CDATA[<p>Hello! Last night I started a print and woke up to a nice blob of plastic after the part broke off and stuck to the extruder. </p><p> </p><p>I went to restart everything and get it cleaned up and noticed that the rotary knob is not functioning, it clicks and sounds normal, but I cannot move through the menu settings aside from clicking the knob in. </p><p>I had a spare LCD control board and I plugged that in to no eval. I thought this may be a firmware issue until I connected it to octoprint and was able to control the printer as normal (all steppers move). </p><p> </p><p>any ideas? I might think about flashing firmware again. </p>]]></content:encoded>
                        <category domain="https://forum.prusa3d.com/forum/original-prusa-i3-mk2-5s-mk2-5-hardware-firmware-and-software-help/">Hardware, firmware and software help</category>                        <dc:creator>Evan</dc:creator>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/original-prusa-i3-mk2-5s-mk2-5-hardware-firmware-and-software-help/rotary-knob-not-responding/#post-720910</guid>
