        PRUSA Control - any update
I do not have an MMU unit so I use PRUSA Control extensively to print multi-layer colored designs. Much easier and quicker that first using Slic3r PE and then ColorPrint to write the G code needed. In one of my previous chats I was told that there will be not update/upgrade. Hope you reconsider.
                            Napsal : 20/05/2019 6:53 pm
                    RE: PRUSA Control - any update
The beta of PrusaSlicer has built in layer colour change ability; it will replace PrusaControl.
                            Napsal : 20/05/2019 9:01 pm
                    Topic starter
 answered:
I am using it now. Pro - gives a good estimate of print time. I just have to get used to the different way you view and set filament change points. My first print changed at first point OK but then, for some reason, tried to change filament again later in the printing. My be operator error but do not remember setting a second point.
                            Napsal : 23/05/2019 9:11 pm
