Prompting for color change when there isn't any
allan.a3
(@allan-a3)
Recently, after the last slicer update, something strange is happening. Every print I attempt is getting halted.
1. Press knob to remove filament
2. Filament removed OK (Yes/No)
3. Press knob to load filament
4. Filament loaded ok (Yes/No)
Print then continues.
This happens three times on every print. I suspect it is a filament color change, but where or what is generating that G-Code?
All my prints are single color.
Respondido : 09/04/2024 5:24 pm
allan.a3
(@allan-a3)
RE: Prompting for color change when there isn't any (Part II)
My STL files have also come from Autodesk Inventor.
The Prusa slicer (2.7.0) shows the color layers when sliced, even though there never were any created.
Respondido : 09/04/2024 5:40 pm
Files > Save Project as
Respondido : 10/04/2024 12:14 am
allan.a3
(@allan-a3)
So I went to produce the .3mf file you requested and went to do it on my Prusa Slicer (2.7.0) at home versus the one at work.
Here's the interesting part, the slicer at home did not have any color changes in the slicing.
So this only happens on my Prusa slicer at work.
I will still produce to file you requested, but it will be tomorrow.
Respondido : 12/04/2024 2:22 am
