Printer printing wrong g code file
Stránka 2 / 2
GordonMcD
(@gordonmcd)
RE: Printer printing wrong g code file
That describes it pretty well. I have learned to make a mental note of the expected print time of the file I want, and if it changes when I press the lever, i stop it. But it often does the same thing again. ( I wonder what would happen if i rewired that lever/switch, and replaced the switch function with a push button. . .) Actually I have not been experiencing the glitch recently.
Napsal : 23/02/2026 9:52 pm
christopher.a2
(@christopher-a2)
I know it isn't a real solution, but using something like OctoPrint would solve your problem and would be less work than rewiring the button, provided you have a raspberry lying around.
Napsal : 24/02/2026 5:01 am
Stránka 2 / 2
