Over-extrusion on MK2.5 with Slic3r PE?
Has anyone else experienced over-extrusion on their MK2.5?
I'm currently using the MK2 Slic3r PE profile with an extrusion multiplier of 0.9 - 0.95 as that gives reasonable results. Default settings seem to over-extrude and leave poor quality prints. I've avoided the MK3 printer profile for Slic3r PE, as that is going to have other speed settings that will be too fast for the MK2.5.
Re: Over-extrusion on MK2.5 with Slic3r PE?
hi! i wanted to ask you i you had any luck with this issue as i have to adjust everytime i print something in order to get "aceptable" quality, many thanks in advance
Did you do an e-step calibration ?
Yes, I've the same "problem". After an calibration of the e-steps, I've an overextrusion. My multiplier is also at about 0.9 - 0.95.
If you use default PRUSA settings for your e-steps, then the multiplier is 100%.
Thomas
i've tried the e-step calibration but the new M92 value is not stored even with M500.
firmware 3.2.0 rc1-461
i'm 5.9mm underextruded (theorically) , but the prints seems to be over extruded...
I'm not an expert. Ma parlo anche italiano 😉
nevermind...i was too dumb and forgot a piece of line....solved for me
