					                		MK2S preheat Bed Thermal Runaway error - while temperature is increasing - Hardware, firmware and software help                                    </title>
                <link>https://forum.prusa3d.com/forum/original-prusa-i3-mk2-5s-mk2-5-hardware-firmware-and-software-help/mk2s-preheat-bed-thermal-runaway-error-while-temperature-is-increasing/</link>
                <lastBuildDate>Sat, 06 Jun 2026 13:33:54 +0000</lastBuildDate>
                        <title>RE: MK2S preheat Bed Thermal Runaway error - while temperature is increasing</title>
                        <link>https://forum.prusa3d.com/forum/original-prusa-i3-mk2-5s-mk2-5-hardware-firmware-and-software-help/mk2s-preheat-bed-thermal-runaway-error-while-temperature-is-increasing/#post-745371</link>
                        <pubDate>Fri, 11 Apr 2025 22:13:34 +0000</pubDate>
                        <description><![CDATA[did the 12 AWG, give you issues when soldering? regards Joan]]></description>
                        <content:encoded><![CDATA[<p>did the 12 AWG, give you issues when soldering? <br /><br />regards Joan</p>]]></content:encoded>
                        <category domain="https://forum.prusa3d.com/forum/original-prusa-i3-mk2-5s-mk2-5-hardware-firmware-and-software-help/">Hardware, firmware and software help</category>                        <dc:creator>JoanTabb</dc:creator>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/original-prusa-i3-mk2-5s-mk2-5-hardware-firmware-and-software-help/mk2s-preheat-bed-thermal-runaway-error-while-temperature-is-increasing/#post-745371</guid>
                        <link>https://forum.prusa3d.com/forum/original-prusa-i3-mk2-5s-mk2-5-hardware-firmware-and-software-help/mk2s-preheat-bed-thermal-runaway-error-while-temperature-is-increasing/#post-745345</link>
                        <pubDate>Fri, 11 Apr 2025 18:32:29 +0000</pubDate>
                        <description><![CDATA[12AWG did the trick - bed now not only doesn&#039;t pull a error, but actually heats up within an appropriate amount of time]]></description>
                        <content:encoded><![CDATA[<p>12AWG did the trick - bed now not only doesn't pull a error, but actually heats up within an appropriate amount of time</p>]]></content:encoded>
                        <category domain="https://forum.prusa3d.com/forum/original-prusa-i3-mk2-5s-mk2-5-hardware-firmware-and-software-help/">Hardware, firmware and software help</category>                        <dc:creator>Leo P</dc:creator>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/original-prusa-i3-mk2-5s-mk2-5-hardware-firmware-and-software-help/mk2s-preheat-bed-thermal-runaway-error-while-temperature-is-increasing/#post-745345</guid>
                        <link>https://forum.prusa3d.com/forum/original-prusa-i3-mk2-5s-mk2-5-hardware-firmware-and-software-help/mk2s-preheat-bed-thermal-runaway-error-while-temperature-is-increasing/#post-742328</link>
                        <pubDate>Tue, 25 Mar 2025 23:29:51 +0000</pubDate>
                        <description><![CDATA[Hi Leo, I don&#039;t think there is a safety hazard using 12 gauge wire, the fuse on the motherboard is much lower rating than the cable rating. BUT it might be difficult actually soldering 12AWG...]]></description>
                        <content:encoded><![CDATA[<p>Hi Leo, <br />I don't think there is a safety hazard using 12 gauge wire, the fuse on the motherboard is much lower rating than the cable rating. <br /><br />BUT it might be difficult actually soldering 12AWG wire, onto the heatbed. <br /><br />regards Joan</p>]]></content:encoded>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/original-prusa-i3-mk2-5s-mk2-5-hardware-firmware-and-software-help/mk2s-preheat-bed-thermal-runaway-error-while-temperature-is-increasing/#post-742328</guid>
                        <link>https://forum.prusa3d.com/forum/original-prusa-i3-mk2-5s-mk2-5-hardware-firmware-and-software-help/mk2s-preheat-bed-thermal-runaway-error-while-temperature-is-increasing/#post-742299</link>
                        <pubDate>Tue, 25 Mar 2025 19:16:37 +0000</pubDate>
                        <description><![CDATA[Yeah, I definitely did. Using 14AWG, it was still slow - but much faster than before. I might try 12AWG, but do you think there&#039;s a limit (safety wise)? Im assuming not
Thank you, regardles...]]></description>
                        <content:encoded><![CDATA[<p>Yeah, I definitely did. Using 14AWG, it was still slow - but much faster than before. I might try 12AWG, but do you think there's a limit (safety wise)? Im assuming not</p>
<p>Thank you, regardless</p>]]></content:encoded>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/original-prusa-i3-mk2-5s-mk2-5-hardware-firmware-and-software-help/mk2s-preheat-bed-thermal-runaway-error-while-temperature-is-increasing/#post-742299</guid>
                        <link>https://forum.prusa3d.com/forum/original-prusa-i3-mk2-5s-mk2-5-hardware-firmware-and-software-help/mk2s-preheat-bed-thermal-runaway-error-while-temperature-is-increasing/#post-741716</link>
                        <pubDate>Sat, 22 Mar 2025 10:08:38 +0000</pubDate>
                        <description><![CDATA[18AWG has a lower current capacity than 16AWG or 14 AWG,using 18AWG wire will cause a greater loss in the wiring and lower power delivery to the Heatbed. LARGER AWG numbers relate to SMALLER...]]></description>
                        <content:encoded><![CDATA[<p><a href="https://storage.googleapis.com/prusa3d-content-prod-14e8-wordpress-forum-prod/2025/03/82d33d59-silicone-wire-table.jpg"><img class="alignnone size-medium wp-image-175336" src="https://storage.googleapis.com/prusa3d-content-prod-14e8-wordpress-forum-prod/2025/03/82d33d59-silicone-wire-table-600x345.jpg" alt="" width="600" height="345" /></a></p><p>18AWG has a lower current capacity than 16AWG or 14 AWG,<br />using 18AWG wire will cause a greater loss in the wiring and lower power delivery to the Heatbed. <br />LARGER AWG numbers relate to SMALLER WIRE...<br /><br /><br />I think you have used the wrong wire<br /><br />regards Joan</p>]]></content:encoded>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/original-prusa-i3-mk2-5s-mk2-5-hardware-firmware-and-software-help/mk2s-preheat-bed-thermal-runaway-error-while-temperature-is-increasing/#post-741716</guid>
                        <link>https://forum.prusa3d.com/forum/original-prusa-i3-mk2-5s-mk2-5-hardware-firmware-and-software-help/mk2s-preheat-bed-thermal-runaway-error-while-temperature-is-increasing/#post-741690</link>
                        <pubDate>Sat, 22 Mar 2025 06:13:27 +0000</pubDate>
                        <description><![CDATA[So the 18awg wire finally arrived and I immediately soldered it.... only to run into the same issue. 12.7V measured across my beds solder joints]]></description>
                        <content:encoded><![CDATA[<p>So the 18awg wire finally arrived and I immediately soldered it.... only to run into the same issue. 12.7V measured across my beds solder joints</p>]]></content:encoded>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/original-prusa-i3-mk2-5s-mk2-5-hardware-firmware-and-software-help/mk2s-preheat-bed-thermal-runaway-error-while-temperature-is-increasing/#post-741690</guid>
                        <link>https://forum.prusa3d.com/forum/original-prusa-i3-mk2-5s-mk2-5-hardware-firmware-and-software-help/mk2s-preheat-bed-thermal-runaway-error-while-temperature-is-increasing/#post-738507</link>
                        <pubDate>Fri, 28 Feb 2025 09:41:27 +0000</pubDate>
                        <description><![CDATA[Hi Leo, you should be measuring at the solder pads.  on the heatbed.strandcount is important, the Prusa wire probably has about 22 strands, Flexible silicone wire has a lot more finer strand...]]></description>
                        <content:encoded><![CDATA[<p>Hi Leo, <br />you should be measuring at the solder pads.  on the heatbed.<br /><br />strandcount is important, the Prusa wire probably has about 22 strands, <br />Flexible silicone wire has a lot more finer strands, which makes it less likely to break, in use<br /><br />at this site on ebay<br />eBay item number:176373249402<br />the 14AWG wire has 400 strands<br />regards Joan</p>]]></content:encoded>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/original-prusa-i3-mk2-5s-mk2-5-hardware-firmware-and-software-help/mk2s-preheat-bed-thermal-runaway-error-while-temperature-is-increasing/#post-738507</guid>
                        <link>https://forum.prusa3d.com/forum/original-prusa-i3-mk2-5s-mk2-5-hardware-firmware-and-software-help/mk2s-preheat-bed-thermal-runaway-error-while-temperature-is-increasing/#post-738483</link>
                        <pubDate>Fri, 28 Feb 2025 04:54:12 +0000</pubDate>
                        <description><![CDATA[The voltage across it is 12.5 Volts. I screwed the POT in a bit more to ensure it was over 12, as it was 11.5 before. I&#039;m measuring the Terminals in the Rambo, not the soldered pads on the h...]]></description>
                        <content:encoded><![CDATA[<p>The voltage across it is 12.5 Volts. I screwed the POT in a bit more to ensure it was over 12, as it was 11.5 before. I'm measuring the Terminals in the Rambo, not the soldered pads on the heated. Should I be checking that as well?</p>
<p>14AWG is a good idea, thank you. Should I be concerned about strand count or anything else besides AWG? Ill likely buy from Ali if it is not an issue.</p>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/original-prusa-i3-mk2-5s-mk2-5-hardware-firmware-and-software-help/mk2s-preheat-bed-thermal-runaway-error-while-temperature-is-increasing/#post-738483</guid>
                        <link>https://forum.prusa3d.com/forum/original-prusa-i3-mk2-5s-mk2-5-hardware-firmware-and-software-help/mk2s-preheat-bed-thermal-runaway-error-while-temperature-is-increasing/#post-738458</link>
                        <pubDate>Thu, 27 Feb 2025 21:27:24 +0000</pubDate>
                        <description><![CDATA[It sounds like the heat bed is taking too long to heat up,What is the voltage across the heatbed terminals, whilst the heatbed is heating?the Mk2 is a  12 VOLT so any stray resistance will h...]]></description>
                        <content:encoded><![CDATA[<p>It sounds like the heat bed is taking too long to heat up,<br />What is the voltage across the heatbed terminals, whilst the heatbed is heating?<br /><br />the Mk2 is a  12 VOLT so any stray resistance will have a significant effect, often the cable starts to deteriorate and go high resistance as strands break in the conductors<br />the original cable is 16AWG. if the terminal voltage is low, you could replace the wires with 14AWG flexible silicone wire, which has a lower resistance <br />regards Joan</p>]]></content:encoded>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/original-prusa-i3-mk2-5s-mk2-5-hardware-firmware-and-software-help/mk2s-preheat-bed-thermal-runaway-error-while-temperature-is-increasing/#post-738458</guid>
                        <title>MK2S preheat Bed Thermal Runaway error - while temperature is increasing</title>
                        <link>https://forum.prusa3d.com/forum/original-prusa-i3-mk2-5s-mk2-5-hardware-firmware-and-software-help/mk2s-preheat-bed-thermal-runaway-error-while-temperature-is-increasing/#post-738423</link>
                        <pubDate>Thu, 27 Feb 2025 18:38:37 +0000</pubDate>
                        <description><![CDATA[I have a MK2S connected to octoprint. This allows me to monitor the exact temp, on a graph. Whenever I try and preheat my printer to ABS temps (255/100), while the bed temperature is increas...]]></description>
                        <content:encoded><![CDATA[<p>I have a MK2S connected to octoprint. This allows me to monitor the exact temp, on a graph. Whenever I try and preheat my printer to ABS temps (255/100), while the bed temperature is increasing, the firmware throws a thermal runaway error and shuts down the print. The issue is, the bed temperature is regularly climbing and not crashing (which I assume is the point of the thermal runaway). If I sit there and repeatedly restart the connection and preheating, it can eventually reach up to ~90 degrees, after around an hour (lol). Steps taken so far include:<br />- Screwing the Pot in PSU to give the bed 12.5V (measured with multimeter)</p><p>- Checked Resistance (~1.5 ohms)</p><p>- Unplugged and replugged bed thermistor and heater in RAMBO</p><p>- Checked Fuses</p><p>- Turned off fan cooling (even though it happens during preheat, not during a print)</p><p>Additionally, the Bed's LED stays on, and there are no melted cables.</p>]]></content:encoded>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/original-prusa-i3-mk2-5s-mk2-5-hardware-firmware-and-software-help/mk2s-preheat-bed-thermal-runaway-error-while-temperature-is-increasing/#post-738423</guid>
