Just to Clarify MK2.5s PINDA Operation
So on the MK2(s) the PINDA would do a 2 minute heat up to stabilize its temp to the bed.
On the MK2.5s it seems this is no longer the case. Is this because the PINDA2 is "live" monitoring the bed heat and adjusting as needed?
So rather than the 2 minute heat up it is sensing and adjusting on the fly?
Just making sure I understand its normal operation and ma running it correctly.
Thanks!
Opublikowany : 05/09/2019 1:10 pm
