					                		How to deal with a situation where during Z calibration, Z calibration is enforced - Hardware, firmware and software help                                    </title>
                <link>https://forum.prusa3d.com/forum/original-prusa-i3-mk2-5s-mk2-5-hardware-firmware-and-software-help/how-to-deal-with-a-situation-where-during-z-calibration-z-calibration-is-enforced/</link>
                <lastBuildDate>Thu, 14 May 2026 19:23:31 +0000</lastBuildDate>
                        <title>RE: How to deal with a situation where during Z calibration, Z calibration is enforced</title>
                        <link>https://forum.prusa3d.com/forum/original-prusa-i3-mk2-5s-mk2-5-hardware-firmware-and-software-help/how-to-deal-with-a-situation-where-during-z-calibration-z-calibration-is-enforced/#post-655349</link>
                        <pubDate>Thu, 04 May 2023 09:02:23 +0000</pubDate>
                        <description><![CDATA[Hi Diem,many thanks for all your suggestions, very much appreciated.I&#039;ve checked all your suggestions with no avail, but finally found the reason of this issue.It seems the pinda probe was a...]]></description>
                        <content:encoded><![CDATA[<p>Hi Diem,</p><p>many thanks for all your suggestions, very much appreciated.</p><p>I've checked all your suggestions with no avail, but finally found the reason of this issue.</p><p>It seems the pinda probe was a tick too high, when I pushed it slightly down to approx 0.8mm distance to the bed everything worked like a charme.</p><p>greatings Gerhard</p>]]></content:encoded>
                        <category domain="https://forum.prusa3d.com/forum/original-prusa-i3-mk2-5s-mk2-5-hardware-firmware-and-software-help/">Hardware, firmware and software help</category>                        <dc:creator>gerhard.w</dc:creator>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/original-prusa-i3-mk2-5s-mk2-5-hardware-firmware-and-software-help/how-to-deal-with-a-situation-where-during-z-calibration-z-calibration-is-enforced/#post-655349</guid>
                        <link>https://forum.prusa3d.com/forum/original-prusa-i3-mk2-5s-mk2-5-hardware-firmware-and-software-help/how-to-deal-with-a-situation-where-during-z-calibration-z-calibration-is-enforced/#post-654574</link>
                        <pubDate>Fri, 28 Apr 2023 09:18:22 +0000</pubDate>
                        <description><![CDATA[I&#039;m trying to remember if overtight trapziodal nuts are an issue with the 2.5, check them and the Z axis linear bearings, maybe lubricate the smooth rods.Cheerio,]]></description>
                        <content:encoded><![CDATA[<p>I'm trying to remember if overtight trapziodal nuts are an issue with the 2.5, check them and the Z axis linear bearings, maybe lubricate the smooth rods.</p><p>Cheerio,</p>]]></content:encoded>
                        <category domain="https://forum.prusa3d.com/forum/original-prusa-i3-mk2-5s-mk2-5-hardware-firmware-and-software-help/">Hardware, firmware and software help</category>                        <dc:creator>Diem</dc:creator>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/original-prusa-i3-mk2-5s-mk2-5-hardware-firmware-and-software-help/how-to-deal-with-a-situation-where-during-z-calibration-z-calibration-is-enforced/#post-654574</guid>
                        <link>https://forum.prusa3d.com/forum/original-prusa-i3-mk2-5s-mk2-5-hardware-firmware-and-software-help/how-to-deal-with-a-situation-where-during-z-calibration-z-calibration-is-enforced/#post-654570</link>
                        <pubDate>Fri, 28 Apr 2023 09:06:00 +0000</pubDate>
                        <description><![CDATA[Hello Diem, thank you for your response.Z axis top end holders are in place and tight. What I&#039;m wondering is that during xyz calibration everything works fine and confirms ok. It even tells ...]]></description>
                        <content:encoded><![CDATA[<p>Hello Diem, thank you for your response.</p><p>Z axis top end holders are in place and tight. What I'm wondering is that during xyz calibration everything works fine and confirms ok. It even tells me that X/Y is perpenticular, so for my understanding the checkpoints for the z-calibration should be within tolerance.</p><p>cheers</p>]]></content:encoded>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/original-prusa-i3-mk2-5s-mk2-5-hardware-firmware-and-software-help/how-to-deal-with-a-situation-where-during-z-calibration-z-calibration-is-enforced/#post-654570</guid>
                        <link>https://forum.prusa3d.com/forum/original-prusa-i3-mk2-5s-mk2-5-hardware-firmware-and-software-help/how-to-deal-with-a-situation-where-during-z-calibration-z-calibration-is-enforced/#post-654389</link>
                        <pubDate>Wed, 26 Apr 2023 23:22:25 +0000</pubDate>
                        <description><![CDATA[Make sure the Z axis top end holder brackets are correctly placed and firm.Cheerio,]]></description>
                        <content:encoded><![CDATA[<p>Make sure the Z axis top end holder brackets are correctly placed and firm.</p><p>Cheerio,</p>]]></content:encoded>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/original-prusa-i3-mk2-5s-mk2-5-hardware-firmware-and-software-help/how-to-deal-with-a-situation-where-during-z-calibration-z-calibration-is-enforced/#post-654389</guid>
                        <title>How to deal with a situation where during Z calibration, Z calibration is enforced</title>
                        <link>https://forum.prusa3d.com/forum/original-prusa-i3-mk2-5s-mk2-5-hardware-firmware-and-software-help/how-to-deal-with-a-situation-where-during-z-calibration-z-calibration-is-enforced/#post-654328</link>
                        <pubDate>Wed, 26 Apr 2023 15:47:31 +0000</pubDate>
                        <description><![CDATA[Ran the assistant calibration successfull. Now when issuing a print I always get above message. So what idiocy is this? During the mesh bed leveling(G80) an error occurs telling to do a z-ca...]]></description>
                        <content:encoded><![CDATA[<p>Ran the assistant calibration successfull. Now when issuing a print I always get above message. So what idiocy is this? During the mesh bed leveling(G80) an error occurs telling to do a z-calibration and then during z-calibration the same error occurs. This goes on and on and on. </p><p>This is really annoying and I'm totally upset.</p>]]></content:encoded>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/original-prusa-i3-mk2-5s-mk2-5-hardware-firmware-and-software-help/how-to-deal-with-a-situation-where-during-z-calibration-z-calibration-is-enforced/#post-654328</guid>
