					                		Big blob after a while on every print - Hardware, firmware and software help                                    </title>
                <link>https://forum.prusa3d.com/forum/original-prusa-i3-mk2-5s-mk2-5-hardware-firmware-and-software-help/big-blob-after-a-while-on-every-print/</link>
                <lastBuildDate>Sat, 07 Mar 2026 09:45:14 +0000</lastBuildDate>
                        <title>RISPONDI: Big blob after a while on every print</title>
                        <link>https://forum.prusa3d.com/forum/original-prusa-i3-mk2-5s-mk2-5-hardware-firmware-and-software-help/big-blob-after-a-while-on-every-print/#post-756589</link>
                        <pubDate>Sun, 06 Jul 2025 13:57:39 +0000</pubDate>
                        <description><![CDATA[Buongiorno, vorrei comprare dallo store un hotend già assemblato per la mia mk2.5s ma non è disponibile, o almeno io non lo trovo. Ho provato a cercare i pezzo singoli per assemblarlo da sol...]]></description>
                        <content:encoded><![CDATA[Buongiorno, vorrei comprare dallo store un hotend già assemblato per la mia mk2.5s ma non è disponibile, o almeno io non lo trovo. Ho provato a cercare i pezzo singoli per assemblarlo da solo, li ho trovati tutti tranne il doppio cavo rosso che porta la corrente. Inoltre la chat live24/7 sembra non essere più disponibile. Come posso fare? Grazie]]></content:encoded>
                        <category domain="https://forum.prusa3d.com/forum/original-prusa-i3-mk2-5s-mk2-5-hardware-firmware-and-software-help/">Hardware, firmware and software help</category>                        <dc:creator>John Left</dc:creator>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/original-prusa-i3-mk2-5s-mk2-5-hardware-firmware-and-software-help/big-blob-after-a-while-on-every-print/#post-756589</guid>
                        <title>RE: Big blob after a while on every print</title>
                        <link>https://forum.prusa3d.com/forum/original-prusa-i3-mk2-5s-mk2-5-hardware-firmware-and-software-help/big-blob-after-a-while-on-every-print/#post-742712</link>
                        <pubDate>Fri, 28 Mar 2025 18:45:28 +0000</pubDate>
                        <description><![CDATA[Thanks againI had did a bad assembly where heat break and nozzle wasn’t firmly touching I think. Now it’s working again 😀]]></description>
                        <content:encoded><![CDATA[<p>Thanks again</p><p>I had did a bad assembly where heat break and nozzle wasn’t firmly touching I think. Now it’s working again 😀 </p>]]></content:encoded>
                        <category domain="https://forum.prusa3d.com/forum/original-prusa-i3-mk2-5s-mk2-5-hardware-firmware-and-software-help/">Hardware, firmware and software help</category>                        <dc:creator>aasbakk</dc:creator>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/original-prusa-i3-mk2-5s-mk2-5-hardware-firmware-and-software-help/big-blob-after-a-while-on-every-print/#post-742712</guid>
                        <link>https://forum.prusa3d.com/forum/original-prusa-i3-mk2-5s-mk2-5-hardware-firmware-and-software-help/big-blob-after-a-while-on-every-print/#post-741871</link>
                        <pubDate>Sun, 23 Mar 2025 02:03:52 +0000</pubDate>
                        <description><![CDATA[Good luck.]]></description>
                        <content:encoded><![CDATA[<p>Good luck.</p><p> </p>]]></content:encoded>
                        <category domain="https://forum.prusa3d.com/forum/original-prusa-i3-mk2-5s-mk2-5-hardware-firmware-and-software-help/">Hardware, firmware and software help</category>                        <dc:creator>JoanTabb</dc:creator>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/original-prusa-i3-mk2-5s-mk2-5-hardware-firmware-and-software-help/big-blob-after-a-while-on-every-print/#post-741871</guid>
                        <link>https://forum.prusa3d.com/forum/original-prusa-i3-mk2-5s-mk2-5-hardware-firmware-and-software-help/big-blob-after-a-while-on-every-print/#post-741854</link>
                        <pubDate>Sat, 22 Mar 2025 22:23:52 +0000</pubDate>
                        <description><![CDATA[Thank you for your suggestions. I’ll try and fix it during next week. the heater block had a lot of marks from the filament on it, but I got rid of most of it. Perhaps I should consider repl...]]></description>
                        <content:encoded><![CDATA[<p>Thank you for your suggestions. I’ll try and fix it during next week. <br />the heater block had a lot of marks from the filament on it, but I got rid of most of it. Perhaps I should consider replacing it. But I’ll check your suggestions first. <br />thanks 😊</p>]]></content:encoded>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/original-prusa-i3-mk2-5s-mk2-5-hardware-firmware-and-software-help/big-blob-after-a-while-on-every-print/#post-741854</guid>
                        <link>https://forum.prusa3d.com/forum/original-prusa-i3-mk2-5s-mk2-5-hardware-firmware-and-software-help/big-blob-after-a-while-on-every-print/#post-741837</link>
                        <pubDate>Sat, 22 Mar 2025 20:41:44 +0000</pubDate>
                        <description><![CDATA[Is there molten filament at the top of the heater block? there may be  a gap between the heatbreak and the nozzle? this could cause the issue you mention. or Overextrusion, could be an issue...]]></description>
                        <content:encoded><![CDATA[<p>Is there molten filament at the top of the heater block? <br />there may be  a gap between the heatbreak and the nozzle? <br /><br /><a href="https://storage.googleapis.com/prusa3d-content-prod-14e8-wordpress-forum-prod/2025/03/56a96173-e3d-v6.jpg"><img class="alignnone size-full wp-image-175356" src="https://storage.googleapis.com/prusa3d-content-prod-14e8-wordpress-forum-prod/2025/03/56a96173-e3d-v6.jpg" alt="" width="512" height="384" /></a><br />this could cause the issue you mention. <br /><br />or Overextrusion, could be an issue, PETG Particularly, picks up, on the nozzle and drops off at the least convenient time... <br />regards Joan<br /><br /></p>]]></content:encoded>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/original-prusa-i3-mk2-5s-mk2-5-hardware-firmware-and-software-help/big-blob-after-a-while-on-every-print/#post-741837</guid>
                        <title>Big blob after a while on every print</title>
                        <link>https://forum.prusa3d.com/forum/original-prusa-i3-mk2-5s-mk2-5-hardware-firmware-and-software-help/big-blob-after-a-while-on-every-print/#post-741833</link>
                        <pubDate>Sat, 22 Mar 2025 19:58:59 +0000</pubDate>
                        <description><![CDATA[I had to replace the nozzle om my MK2.5. Same 0,4 nozzle as before.Also replaced the PTFE tube and cleaned the &quot;heatsink?&quot; that the nozzle is screwed into.I did the XYZ calibration, and the ...]]></description>
                        <content:encoded><![CDATA[<p>I had to replace the nozzle om my MK2.5. Same 0,4 nozzle as before.</p><p>Also replaced the PTFE tube and cleaned the "heatsink?" that the nozzle is screwed into.</p><p>I did the XYZ calibration, and the height calibration. The calibration print looks nice.</p><p>But every time I print something a blob appears after a while. Maybe about 20 min. Roughly 5x5mm and 2 mm high. After this the further printing is scewed, and I have to stop it.</p><p>I don't know what to do to fix this. Can someone help?</p><p>Attaced a couple of photos</p><p><a href="https://storage.googleapis.com/prusa3d-content-prod-14e8-wordpress-forum-prod/2025/03/338f90af-img_5250-scaled.jpeg"><img class="alignnone size-medium wp-image-175354" src="https://storage.googleapis.com/prusa3d-content-prod-14e8-wordpress-forum-prod/2025/03/338f90af-img_5250-600x500.jpeg" alt="Size 60x75x4" width="600" height="500" /></a> <a href="https://storage.googleapis.com/prusa3d-content-prod-14e8-wordpress-forum-prod/2025/03/3c0edbd1-img_5251-scaled.jpeg"><img class="alignnone size-medium wp-image-175355" src="https://storage.googleapis.com/prusa3d-content-prod-14e8-wordpress-forum-prod/2025/03/3c0edbd1-img_5251-600x500.jpeg" alt="Blob seen a little to the left and up from the center" width="600" height="500" /></a></p><p> </p>]]></content:encoded>
                        <category domain="https://forum.prusa3d.com/forum/original-prusa-i3-mk2-5s-mk2-5-hardware-firmware-and-software-help/">Hardware, firmware and software help</category>                        <dc:creator>Jon Anders Aasbakk</dc:creator>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/original-prusa-i3-mk2-5s-mk2-5-hardware-firmware-and-software-help/big-blob-after-a-while-on-every-print/#post-741833</guid>
