Bed Thermistor runaway
I just got a Bed Thermistor runaway error. Restarting my 2.5 and doing a selftest I get a “Heater/Thermistor not connected” error. The cable looks fine (not bent, not broken anywhere), the board and pin thereon look fine, the Thermistor is properly connected to the downside of the bed.
It seems that also the heating does not work. Setting both hotend and bed to a certain temperature (e.w. 230/85) heats the hotend, but the bed stays at room temperature.
I checked a few search results, where I found these, but i sadly don't have a multimeter available. What can I do now and check?
Re: Bed Thermistor runaway
what temperarure do the bed and extruder thermistors indicate when at room temperature?
if the extruder temperature is correct and the bed well below temperature, then it is likely the bed thermistor is faulty
Both temperatures are ok (27 degrees); fuses are ok. Still looking for further issues.
Today I found some time to check again. I carefully unplugged and replugged all cables going to the heatbed, followed the idea of unplugging the PINDA probe on first boot ( see https://shop.prusa3d.com/forum/assembly-and-first-prints-troubleshooting-f62/heater-thermistor-not-connected--t18904.html#p116070 ) and instead of a complete selftest first just tried to set the temperature of the heatbed.
It heated!
So I powered down again, replugged the PINDA (though not sure whether that really had an effect, but if somebody sees this - maybe it does) and did a selftest - seems to be fine again.
I am not completely sure what caused this, maybe one of the heating current cables came a little loose, but a first small print already finished positively.
Thanks joan.t for the tips.
best wishes!
Joan
...sadly that only worked for about 4 prints. So one of my cables might have a damage I fear.
🙁 Joan
Today I found some time again.
* all cables are ok, I checked them
* I replaced the heatbed with a replacement one I already had here
* I also checked all the cables of that one
* The selftest fails because the temperature stays at room temperature and the heatbed does not heat
* fuses still ok
* the “trick” from before to once start without PINDA attached did also not work
I am out of ideas (and I just got it back about 1.5 months back from prusa repair, so somehow I am really not getting started with my 2.5).
