[Solved] Autoload not working
alancastell
(@alancastell)
Just did the mk2s to 2.5s upgrade, and everything works fine except autoload.  I double checked the cables, and even tested the 5v at the sensor end and it was correct.  I can feel the ball being pushed aside, and yet nothing happens.  I turned it off and do a manual load and everything works fine.
Wondering what might be the cause, or if anyone has a suggestion.  Like to get it working but not a deal breaker.
I have a Mk3S and it works correctly on that one.
Posted : 06/07/2019 9:14 pm
alancastell
(@alancastell)
RE: Autoload not working
Solved.
Read about how you can look at the sensor data, under the LCD/Support.  Checked and saw that there was a value of 1 when there wasn't filament in there.  Undid the top to get access to the IR sensor and moved it a bit and the value went to 0.  Removed the sensor and put a small paper washer under it where you screw it in.  Value stayed at 0 after everything was put back together.  Autoload now works.
Posted : 06/07/2019 11:07 pm
