After Upgrade to Mk2.5S my print bed got smaller
Hey there,
I just upgraded to Mk2.5s. When doing the first test prints, I realized there is a ~5 - 7mm wide area at the left side of the print bed that can no longer be printed. If I print a gcode file that worked perfectly before the update, the skirt is now colliding with the print.
The first picture shows the problem, the second picture shows how the skirt should be printed.
I am using the Mk2.5 commercially, and this file has been printed dozens of time before, with no problems. It happens on other files also.
I contacted the prusa support and they told me to disable the skirt! Are they kidding? That's not resolving the problem!
Respondido : 18/04/2019 1:06 pm
Re: After Upgrade to Mk2.5S my print bed got smaller
After the update, did you run the full XYZ calibration?
Respondido : 20/04/2019 8:54 pm
