2.5 unusual behaviour
NoxAstrum
(@noxastrum)
I just installed the latest Prusa slicer and firmware, since then I've been seeing a couple of issues:
1. When printing a certain part in ABS, I see the staircase effect in the Y axis. Twice it happened early in the print (20 layers?) and after re-slicing, it happened later in the print (100 layers?). It seems to have offset the Y axis by about 2mm. I've inspected every part of the Y axis, there's nothing loose, jammed or hung up. It doesn't happen when I print the same part in PLA, but I need to use ABS to help reduce deformation in direct sunlight.
2. While printing another part, it stops about 60% through and tells me to unload the filament. Then when I reload, the extruder motor skips. I use pronterface to extrace the filament, I cut the end off and sometimes can manage to reinsert it and get it to extrude successfully. It's a brand new nozzle I just replaced today.
I'm wondering if the problems are related or not. I wonder if #1 (and/or #2) could be due to some issue with the slicer or firmware. I thought #1 could be the higher bed temps for ABS could be distorting the bed and causing the bearings to bind, but I tested the range of motion and it seems to move ok. I'm wondering if #2 could be a problem with the filament sensor, or even poor quality filament that doesn't want to melt.
At this point, I'm thinking about rebuilding the hotend. Any thoughts would be appreciated.
This topic was modified 3 years ago by NoxAstrum
Posted : 18/06/2023 2:20 am
