					                		Upgrading a MK2.5S+ with EinsyRambo Board? - General discussion, announcements and releases                                    </title>
                <link>https://forum.prusa3d.com/forum/original-prusa-i3-mk2-5s-mk2-5-general-discussion-announcements-and-releases/upgrading-a-mk2-5s-with-einsyrambo-board/</link>
                <lastBuildDate>Mon, 08 Jun 2026 23:27:29 +0000</lastBuildDate>
                        <title>RE: Upgrading a MK2.5S+ with EinsyRambo Board?</title>
                        <link>https://forum.prusa3d.com/forum/original-prusa-i3-mk2-5s-mk2-5-general-discussion-announcements-and-releases/upgrading-a-mk2-5s-with-einsyrambo-board/#post-655667</link>
                        <pubDate>Sun, 07 May 2023 15:16:21 +0000</pubDate>
                        <description><![CDATA[Hi Joan,Thanks for the reply.  After some more searching, this is basically what I am looking to dosince it does require some firmware tweaks, I&#039;m probably just going to stick with the MiniR...]]></description>
                        <content:encoded><![CDATA[<p>Hi Joan,</p><p>Thanks for the reply.  After some more searching, this is basically what I am looking to do:</p><p lang="x-none">https://forum.prusa3d.com/forum/postid/74913/</p><p lang="x-none">However, since it does require some firmware tweaks, I'm probably just going to stick with the MiniRambo.</p><p lang="x-none">Thank you.</p>]]></content:encoded>
                        <category domain="https://forum.prusa3d.com/forum/original-prusa-i3-mk2-5s-mk2-5-general-discussion-announcements-and-releases/">General discussion, announcements and releases</category>                        <dc:creator>Jason</dc:creator>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/original-prusa-i3-mk2-5s-mk2-5-general-discussion-announcements-and-releases/upgrading-a-mk2-5s-with-einsyrambo-board/#post-655667</guid>
                        <link>https://forum.prusa3d.com/forum/original-prusa-i3-mk2-5s-mk2-5-general-discussion-announcements-and-releases/upgrading-a-mk2-5s-with-einsyrambo-board/#post-655624</link>
                        <pubDate>Sun, 07 May 2023 07:21:41 +0000</pubDate>
                        <description><![CDATA[you would need a lot more... 24v heat bed, mk3 Y platform (heat bed mountings are different between 12 volt and 24 volt heatbed), 24 volt heater for the hot end, revised Z brackets to restor...]]></description>
                        <content:encoded><![CDATA[<p>you would need a lot more... <br />24v heat bed, mk3 Y platform (heat bed mountings are different between 12 volt and 24 volt heatbed), 24 volt heater for the hot end, revised Z brackets to restore the increased Z height.  sort out Y motor direction, the Mk2 frame has the motor on the opposite side of the belt drive compared to the Mk3 frame, so the Y  axis would go backwards<br />new Y Belt fixture to match the New Y Platform<br /><br />regards Joan</p>]]></content:encoded>
                        <category domain="https://forum.prusa3d.com/forum/original-prusa-i3-mk2-5s-mk2-5-general-discussion-announcements-and-releases/">General discussion, announcements and releases</category>                        <dc:creator>JoanTabb</dc:creator>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/original-prusa-i3-mk2-5s-mk2-5-general-discussion-announcements-and-releases/upgrading-a-mk2-5s-with-einsyrambo-board/#post-655624</guid>
                        <title>Upgrading a MK2.5S+ with EinsyRambo Board?</title>
                        <link>https://forum.prusa3d.com/forum/original-prusa-i3-mk2-5s-mk2-5-general-discussion-announcements-and-releases/upgrading-a-mk2-5s-with-einsyrambo-board/#post-655611</link>
                        <pubDate>Sun, 07 May 2023 02:00:02 +0000</pubDate>
                        <description><![CDATA[I currently have an MK2.5 that has been upgraded to a &quot;MK2.5S+&quot; using this guideI have the updated Pinda 2 probe and steel sheet bed, etc.However, due to recent problems I&#039;ve been having wit...]]></description>
                        <content:encoded><![CDATA[<p>I currently have an MK2.5 that has been upgraded to a "MK2.5S+" using this guide:<br />https://help.prusa3d.com/article/upgrading-mk2-s-and-mk2-5-s-to-mk2-5s_200009</p><p>So, I have the updated Pinda 2 probe and steel sheet bed, etc.</p><p>However, due to recent problems I've been having with heatbed/PSU connector melting issues, I am considering replacing the mainboard.  It looks like a new EinsyRambo is about the same price as a replacement for my current MiniRambo 1.3a.</p><p>How feasible is it to upgrade to the EinsyRambo?  From what I've read so far, it seems like I would just need a new 24V PSU, and part cooling fan.  If I did this, would I then be able to run MK3 firmware?  Are there any upgrade guides out there that would might be helpful?  What would be the minimum I would need to just get it functioning with the new board?</p><p>Thanks</p>]]></content:encoded>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/original-prusa-i3-mk2-5s-mk2-5-general-discussion-announcements-and-releases/upgrading-a-mk2-5s-with-einsyrambo-board/#post-655611</guid>
