Slice Multiple Objects with Different Slice settings Per Object.
mikebackon
(@mikebackon)
Hi all. Does anyone know in PrusaSlicer how can I:
insert two or more separate objects.
Slice these two or more separate objects each with different slice and print settings? (including printer settings like retraction).
Lets say I put a cube and a cylinder and I want to slice the cube with Gyroid Infill and default retraction settings, and at the same time slice the cylinder with Concentric Fill Pattern and no retraction at all?
Thank you.
Posted : 09/08/2019 5:50 am
RE: Slice Multiple Objects with Different Slice settings Per Object.
In the parts view window you can right click and insert changes to slice settings. Lots of options like perimeters, infill, layer height.  You can add these to each part in the project.
Posted : 09/08/2019 7:19 am
mikebackon
(@mikebackon)
Posted by: mikebackon
Hi all. Does anyone know in PrusaSlicer how can I: URL removed by moderator
Thank you.
Thank you
Posted : 16/08/2019 12:55 pm
Ingo
 Ingo
(@ingo)
I didn't find settings for retraction though
Posted : 15/11/2019 3:26 am
