New printed parts C1/R4 - MK3S/MK2.5S/MMU2S
Pagina 5 / 5
takedownca
(@takedownca)
RE: New printed parts C1/R4 - MK3S/MK2.5S/MMU2S
Finally getting around to upgrading my MK3 to a MK3S, and after that adding MMU2S. I've had the parts laying around for a while and it seems some of them have been updated beyond R4 (like the extruder-motor-plate which is at R5). Is there a changelog somewhere that states what the changes were, so I know whether or not it's worth printing the newer version?
Postato : 16/03/2021 10:01 pm
Utenti
I have not installed them yet.  You could always do it and post about it.
Postato : 17/03/2021 2:12 am
DanaF
(@danaf)
I have a MK2.5S. Correct me if I'm wrong, but aren't all the MK3 extruder printed parts the same for the MK2.5?
The MK2.5 parts they have listed seem to be old, while I see a few updates have been done with the Mk3 parts. As far as I can tell, I see no reason why I can't use them. But I want to be sure.
Questo post è stato modificato 4 years fa da DanaF
Postato : 14/05/2021 3:59 pm
Chicago Keri
(@chicago-keri)
@danaf
I think you are right. I am using a Mosquito-specific extruder meant for the MK3s+, the R6, on my MK2.5s without issue.
The MK 2.5s filament sensor, ball, and PINDA 2 from the R4 extruder all fit perfectly into the R6, it bolts to the X-carriage without issue and seem to work well without any further modifications.
I also wonder why the R6 is not listed for the MK2.5s.
¡no entiendo Español!
Nein! Nicht Versteh!
Я немного говорю по-русски но не очень хорошо, и...
I'm not very good at English either! Maybe someday I'll find a language I'm good at?
Postato : 16/05/2021 6:53 pm
DanaF
(@danaf)
Thanks for the reply, Chicago. It might be possible to do some research on Github to determine this, but I'm not very proficient at navigating Github.
Postato : 16/05/2021 7:19 pm
Utenti
Posted by: @danaf
I think you are both correct.  I upgraded my eBay purchased MK2 all the way to an MK3S.  I am pretty sure they similar if not the same.
Postato : 16/05/2021 10:18 pm
I may be out of date.
the Mk2 used physical end stop switches for X & Y Axis,
to the best of my knowledge the mk2.5 setup retains these endstops. the Y axis is part of the Y belt clamp, but the X axis endstop is a tiny lump that bolts on to the left hand side of the X carriage
https://help.prusa3d.com/article/upgrading-mk2-s-and-mk2-5-s-to-mk2-5s_200009
Postato : 18/07/2022 7:42 pm
Pagina 5 / 5
