Export from tinkercad to obj file then into Prusaslicer gives poor quality on sloped surfaces
Paulmac
(@paulmac)
When exporting from Tinkercad to an obj/stl file then importing that file into prusa I get a problem where  top and bottom perimeters are not filled in on the sloped part of the item.
In Tinkercad the surfaces are smooth as shown below
Tinkercad shows surfaces as smooth
Yet When I view the item in Prusa after importin I can see that the perimter hasnt been sufficiently filled in where the slope begins as shown below:-
After import to Prusaslicer
So the end product looks like this:-
Bow printed shows infill and top and bottom perimeter not filled in on sloped part of surface
As you can see the smooth outer perimeter is failing at the start of the sloped surface. has anyone any ideas ?
Edited by Joan Tabb, to show pictures
This topic was modified před 4 years 2 times by Paulmac
Napsal : 02/04/2022 8:42 am
Paulmac
(@paulmac)
Hi Joan , thanks for inserting the pics for me However you have inserted pic 1 twice, the second picture should be as per below, unfortunately I have no way of editing the original post.
This post was modified před 4 years by Paulmac
Napsal : 03/04/2022 8:26 am
Paulmac
(@paulmac)
Also pic 3 hasnt sized well so I have turned it to horizontal to display more of the problem, see below.
Outer perimeter is smooth up to start of slope then the outer perimeter stops and all we can see is infill
This post was modified před 4 years 2 times by Paulmac
Napsal : 03/04/2022 8:41 am
RE: Export from tinkercad to obj file then into Prusaslicer gives poor quality on sloped surfaces
can you save your prusa slicer setup in a project file (.3mf file)   and then ZIP the file so that you can attach it to your next post,
then we can try and make more suggestions.
Napsal : 03/04/2022 10:35 am
Paulmac
(@paulmac)
Hi Joan, Please  find bow6.zip uploaded
Napsal : 03/04/2022 9:23 pm
