3.13.1 Firmware for the MK2.5 and MK2.5S
Hello all, we are releasing a new firmware version that addresses a rare issue with calibrations. If you do not have this issue, then you do not need to update your firmware.
Summary
- XYZ calibration fixed
This is the stable release of firmware 3.13.1 addressing an issue discovered by the community and verified by our internal testing. If your printer has not experienced the problem described below, you can skip this update.
Some printers encountered a problem during XYZ calibration where the Z-axis failed to lift correctly. This led to insufficient clearance for installing the steel sheet and, in some cases, resulted in the nozzle crashing into the heatbed. We have identified and fixed this issue in this release. This also resolves #4304.
Thanks to the community members reporting this issue: @jeepac, @D-an-W, @sdh2, @sarusani, @Patrick-Schmitt, @bigsmalloverall, @naldarn and @jwall87
Please report any bug here:
https://github.com/prusa3d/Prusa-Firmware/issues
Download Link:
https://github.com/prusa3d/Prusa-Firmware/releases/tag/v3.13.1
How to flash the firmware:
https://help.prusa3d.com/en/article/firmware-updating-mk3s-mk3s-mk3_2227
Shane (AKA FromPrusa)
