[Solved] X-axis eEndstop error during selftest
Hoboken
(@hoboken)
I just finished upgrading my MK2.5/MMU2 to MK2.5S/MMU2S but running into issues when running the selftest. It comes with the error that "endstop not hit motor" while checking the x-axis. Why this error as my printer doesn't have any physical endstops installed?
The Prusa printing handbook refers with these kind of issues to the MK2S but I had a original MK2, later upgraded to MK2.5 and now to MK2.5S.
I updated the firmware to the latest version and did a factory reset but the issue keeps coming back.
What is wrong?
Thanks for any help.
Alex
Posted : 17/05/2019 6:22 pm
Dave Durant
(@dave-durant)
RE: X-axis eEndstop error during selftest
You are saying that you don't have an X endstop? I think you should have one of those, as well as a Y endstop. The PINDA acts as the Z endstop.
edit: but I'm no expert.. My MK2S -> MK2.5 definitely does.
This post was modified 7 years ago by Dave Durant
Posted : 23/05/2019 8:36 pm
Hoboken
(@hoboken)
Solved : RE: X-axis eEndstop error during selftest
This problem has been solved, I missed adding the end-stop, described in "Stap 65 Endstop-block assembly". For this upgrade from MK2.5/mmu to MK2.5s/mmu2s it was neceary to use only some chapters/staps of two different manuals, didn't make it easy to know for sure if everything was correctly build.
Posted : 07/06/2019 7:17 am
