Strange issues after MK2S to MK2.5 upgrade
Programmatic
(@programmatic)
My printer has not been preforming very well since doing the upgrade. The combo of issues has been a nightmare to track down.
  • It's over extruding. My printer is at the default estep value and I have to bring the extruder multiplier down .85 (Even with prusa filamnet).
  • Layer adhesion has been horrible. I think I narrowed it down to low temps. I've had much better success cranking up the temperature 20-25C. (Same materials I used before the upgrade)
  • The extruder keeps clicking and produces a mess when I try to print .15m layers. This might be related to the heat as well.
  • The part cooling fan only works on the left side of the build plate and even then, it seems to be dying.
  • When I tried to print 0.15mm and extruder was clicking.
    What the heck is up with the over extrusion?!
    How do I verify my suspicions about low temp. If it is a low temp issues, do I need to buy a new thermistor?
    I'm going to upgrade to the R3 extruder. Going to replace the bad fan while I have it torn apart. What other maintenance things should I be looking out for during the upgrade?
    Postato : 06/03/2019 9:26 pm
    Re: Strange issues after MK2S to MK2.5 upgrade
    Hi Matt..
    silly question,
    did you reload the correct firmware?
    Joan
    Postato : 06/03/2019 10:14 pm
    Programmatic
    (@programmatic)
    Not a silly question at all 😀 Running MK25_3_6_0_RAMBo13a_en-cz
    Postato : 07/03/2019 12:07 am
    Programmatic
    (@programmatic)
    I read that misaligned bondtech gears can cause over extrusion. Gears look fine to my eyes.
    Postato : 07/03/2019 7:07 pm
    Programmatic
    (@programmatic)
    Turns out default e step values changed for MK2.5
    // MK2.5
    #define DEFAULT_AXIS_STEPS_PER_UNIT {100,100,3200/8,133}
    // MK2
    #define DEFAULT_AXIS_STEPS_PER_UNIT {100,100,3200/8,161.3}
    My e steps are 161.3, not 133 :O
    Ran M502 (didn't know it was a thing until I started digging through the source code xD), looks like there are a few differences between MK2.5 default settings and what is written to my EPROM. Going to write the defaults to EPROM and see how it goes.
    I have never changed any values other than e step before. This tells me that my EPROM never got reset after upgrading to MK2.5. I wonder if there was a step in the instructions that I missed?
    That still does not solve my temp problem though. Although I need a method to verify it is indeed a temperature problem. Anyone have any idea how I can test it?
    Postato : 07/03/2019 7:59 pm
