Strange issues after MK2S to MK2.5 upgrade
My printer has not been preforming very well since doing the upgrade. The combo of issues has been a nightmare to track down.
When I tried to print 0.15mm and extruder was clicking.
What the heck is up with the over extrusion?!
How do I verify my suspicions about low temp. If it is a low temp issues, do I need to buy a new thermistor?
I'm going to upgrade to the R3 extruder. Going to replace the bad fan while I have it torn apart. What other maintenance things should I be looking out for during the upgrade?
Re: Strange issues after MK2S to MK2.5 upgrade
Hi Matt..
silly question,
did you reload the correct firmware?
Joan
Not a silly question at all 😀 Running MK25_3_6_0_RAMBo13a_en-cz
Turns out default e step values changed for MK2.5
// MK2.5
#define DEFAULT_AXIS_STEPS_PER_UNIT {100,100,3200/8,133}
// MK2
#define DEFAULT_AXIS_STEPS_PER_UNIT {100,100,3200/8,161.3}
My e steps are 161.3, not 133 :O
Ran M502 (didn't know it was a thing until I started digging through the source code xD), looks like there are a few differences between MK2.5 default settings and what is written to my EPROM. Going to write the defaults to EPROM and see how it goes.
I have never changed any values other than e step before. This tells me that my EPROM never got reset after upgrading to MK2.5. I wonder if there was a step in the instructions that I missed?
That still does not solve my temp problem though. Although I need a method to verify it is indeed a temperature problem. Anyone have any idea how I can test it?
