OctoPrint suddenly no longer able to heat up hot end / extruder
Walcott84
(@walcott84)
My OctPrint and Monoprice Maker Select IIIP (A Wanhao i3 Duplicator Plus clone) were working fine, but suddenly today the hot end won't heat up anymore. I tried disconnecting the OctoPrint USB and resetting the printer power, and it still couldn't heat up the extruder, such as through the filament menu.
But then it got weird.
I left it off for a few hours and turned it on to see if it was getting 12 V to the hot end, and it was heating up again! So I plugged in the OctopPrint and we're back to square one, the extruder has just been cooling down. I know the thermistor is working, because it's accurately following the temp, such as following the cooldown after the heating stopped working again.
Is it possibly I have a dead hot end and for some reason it temporarily started to work again? Maybe an intermittent short?
I guess the next step is to open up the base and look at the connector to the motherboard, and or measure for 12 V greatpeople
Opublikowany : 27/09/2021 10:01 am
Stress Fracture.
The wires to the Hot end, are part of the bundle from the Rambo case to the back of the X axis carriage,
these wires flex every time the carriage moves from side to side.
repeated flexing can work harden the wires and cause them to be intermittent continuity.
or removing a blob of doom , can similarly damage the wires near the heater...
options are to replace the entire heater and wire (especially if you think the damage may be near the heater cartridge, )
or  replace the wires from the fixed part of the X carriage, into the rambo case
I would use 16AWG flexible silicone wire to replace this section of the wiring if I believed the issue was in the flexible section of the wire.
I would use solder and heat shrink sleeve to join the wires!
Opublikowany : 27/09/2021 1:09 pm
