Need help to Identify the issue
STAFFSMITH.EU
(@staffsmith-eu)
Hey
I printed a Benchy to check the quality of my assembly and software.
I got an fail print bud i cant identify the issue.
What i checked: Belts, drive couplers, rods and printingspeed.
any idears?
Postato : 12/01/2019 10:39 pm
RichHomieTee
(@richhomietee)
Re: Need help to Identify the issue
Not to annoy you but did you try to re calibrate the x, y, and z-axis before you printed the models shown above or after?
Postato : 12/01/2019 10:49 pm
Looks like the calibration went adrift, then returned to the same alignment it started with, that suggests to me that the drive gear on the motor has
loose screws, and that most importantly one of the screws is not tightened against the centre of the flat on the motor shaft
Postato : 12/01/2019 11:04 pm
toaf
 toaf
(@toaf)
looks like a tim burton print... is the extruder in the carriage correctly?
Postato : 12/01/2019 11:09 pm
STAFFSMITH.EU
(@staffsmith-eu)
I rechecked all the screws on the motor´s, nothing lose ore not on the flat part.
yes i calibrated before that print, and 2 times after that one.
im doing a simpel test print at the moment so far it looks good.
woops, i postet in the wrong category, this shut be in MK3, my fault.
thanks so for the help, tomorrow i will give this boat a second try.
btw "Tim Burton Print" is a good one. 😉
Postato : 13/01/2019 12:10 am
RichHomieTee
(@richhomietee)
I would save that print if I were you 💡 Anyways good luck!
Postato : 13/01/2019 3:45 am
STAFFSMITH.EU
(@staffsmith-eu)
Problem is gone! 😀
Test print looks rly good to me, marginal uncleanliness.
Postato : 13/01/2019 4:05 pm
