IR sensor does not fit in MK2.5s upgrade - I think I printed the wrong parts
thebrucecrowder
(@thebrucecrowder)
I am upgrading my mk2 (not "s") to mk2.5s. I made it to Step 6 of Section 4 and realized that the IR sensor has an additional protrusion that prevents it from fitting into the extruder body as printed. My assessment is that I must have downloaded and printed the wrong parts (I guess the MK2.5 parts).
My question is this - what other parts should I print? Is the extruder body the ONLY different part between mk2.5 and m2.5s? Thankfully I have an additional printer so I can do this if necessary, but I don't have lots of extra filament.
The sensor has 3 pins and says "PRUSA Rev0.4" on the PCB, like the red one shown here:
Here is the assembly manual page
Any advice is appreciated. Thanks.
Opublikowany : 04/05/2020 8:35 pm
RE: IR sensor does not fit in MK2.5s upgrade - I think I printed the wrong parts
I think you have made an error
you show the Mk2.5S IR filament sensor, and
you show the Mk2.5 Laser Filament sensor housing...
I think you need this assembly guide
https://help.prusa3d.com/en/tag/mk2-5s/
this is the housing that is required for the Mk2.5S IR filament sensor
Regards Joan
Opublikowany : 04/05/2020 9:23 pm
